Page 127 of 139 FirstFirst ... 2777117125126127128129137 ... LastLast
Results 1,891 to 1,905 of 2085
  1. #1891
    Quote Originally Posted by "Z" UTE View Post
    I had a mate prep his own car, all trim removed, rust repairs done etc. Hired a booth for $200.00, the guy at the shop sussed that my mate had no idea on how to paint, and offered to wave the gun for another $200.00. He was just going to be sitting in the office waiting for my mate to do the job anyway, so painter collects another $200.00, mate is real happy with the paintjob.
    You can buy Urethane 2pac really cheap, it is the stuff they use on trucks. It is as tough as nails. 4 litres of topcoat colour and 2 litres of hardener for under $200.00. Autothane is one of the brands of Urethane I have used, and I can not recommend it highly enough.
    You just have to have all the prep work and as much masking as possible done before you turn up at the booth. Look around and get some prices from different paint shops.
    cheers Chuck.
    Chuck can you PM contact details for this Booth ?
    Got a workmate ready and raring to paint his car but needs a booth.
    Is happy to pay in cash and has all his stuff ready to go.
    Jeremy
    Canberra Celica Group
  2. #1892
    Aug 2011
    Anything is better then a dodgy coat of primer someone sprayed on it lol
  3. #1893
    Quote Originally Posted by Sirsh View Post
    I've searched the net for renting booths, Couldn't find anything over here. Plus I don't have the gear nor know anyone who does.
    Not everything is on the "Net" Most panel beater I know would not know how to set up a web page!
    Look through the phone book and you will probably find half a dozen paint shops in a light industrial arae close to where you are. Go and check them out. See if anyone is willing to accomodate you. As for gear, a SuperCheap $60-80 gun and a bunnings respirator with vapour filters $30.00.
    Like ian said though, the finish has to be good or it could be a monumental waste of time that devalues your car.
    Jezz pm sent.
    MS51Crown Coupe,
  4. #1894
    Agreed, if you paint your TA22 with any form of enamel, you will drop its value significantly. If you do it with a brush/roller/rattle can, even worse so.
    Acrylic will be the least mess, best result method of painting your TA22 which won't fuck it completely and ruin any hope of it being properly restored later without huge painstaking effort. Acrylic can be painted in your back yard without the need for any shed/garage/enclosure etc, and for about $200 worth of gear, it will save you huge headaches (yup those $100 superthief auto air compressors will actually allow you to spray a car - have done it before, and their cheap gravity HVLP spray guns aren't too bad for putting on a coat of jam - bought mine on special for $40)
  5. #1895
    Oct 2009
    Hold your breath and shoot it in 2k? Can't be worse than smoking a few packs of smokes
  6. #1896
    Quote Originally Posted by dnegative View Post
    no, they're both bad but inhaling solvents and paint (via the lungs, mucous membranes and the skin) will make you sick as. Get some disposable overalls from bunnings and a vapor-proof (not just particulate) mask.
    edit: I'm assuming you forgot to italicise your post?
  7. #1897
    Problem with the 2k is that it stays tacky for too long, and is bad for bugs, dust, leaves and overspray. Acrylic dries quick enough that overspray is a non-issue, and bugs, dust and leaves are not a huge problem.
  8. #1898
    Quote Originally Posted by o_man_ra23 View Post
    Reduce your normal hardener by 20% and add 20% fast hardener. No tacky hassles.
    MS51Crown Coupe,
  9. #1899
    Does black acrylic need clearcoat? I read different shit all the time and most of the time I've read that basic colours (as in not metallics, pearls etc) dont need a clearcoat but then I read about UV scorching and birdshit/ tree sap stains etc...
  10. #1900
    It still won't dry nearly as quick as Acrylic... that shit drys like nobody's business and is far more suited to open air spraying than a 2k with fast hardener.
  11. #1901
    Nov 2009
    so i was spraying my rims today and a little bit of primer escaped through the tape and onto the polished outer lip, will turps get it off even though its dry?
  12. #1902
    What type of primer? Thinners of the appropriate type should remove it if it isn't enamel...
  13. #1903
    Quote Originally Posted by cheviotrola View Post
    Buy black acrylic topcoat, it will have clear in it to give the gloss. However if you purchase black basecoat, then you definately will require a clearcoat over that.
    cheers Chuck.
    MS51Crown Coupe,
  14. #1904
    Nov 2009
    This is the primer on the left
    It doesnt say anywhere on the can that its enamel
    thanks oman i'll try thinners, hopefully that'll get rid of it
  15. #1905
    White Knight use a xylene based thinner for some of their paints.
    Last Post: 06-01-2010, 08:34 PM
    Last Post: 22-09-2007, 11:52 PM
    Last Post: 11-01-2006, 09:53 AM
