Results 16 to 30 of 44
Thread: what rear end to use for drifting a ra23
    Default Re: what rear end to use for drifting a ra23
    Quote Originally Posted by DQIKST
    agreed,
    there is soo much info for the classic celicas on this site, im surpised we dont have a sub section just for the classic celicas, and toymods as a mother club,
    you're an ideas man dqikst
    Geez, a hilux and a volvo are both massively overkill, but i dunno about the T series either. With alot of abuse i killed a tseries center and two axles... With a standard 18rc and a locker...
    Jase
    JZA023
    Drop and Fit Grease Monkey mumblezzz's Avatar
    It depends on the way you treat it. Josh Young still uses a T diff behind a 1UZFE and it hasnt let go. I've only broken crappy welded T centres where the welds just fell apart and chewed out the gears.
    053Style
    Forum Sponsor Conversion King
    i still dont know why ppl always use hilux diffs, yes there strong but they weigh a tonne.
    for a light circuit car id use an F series, they will cop a shiteload of abuse and give you less unsprung weight than a G series (better handling)
    if it was a drag car then by all means use a G series coz you dont need to worry about unsprung weight as much.
    linden
    Yep, MS112 Crown diff would be the go here, has an F series centre which is plenty strong and it has disc brakes with drum handbrake. There are also lots of options for the diff centre as they're used in Hilux 4WD's; torsen LSD, clutch LSD, locker, air locker, mini spool, full spool, all easily available.
    F series diff, FWD offset rear rims (or pump the guards Uleh!!) 2-way LSD and RT142 rear discs... then your set.
    If your EVER going to drive the car on the streets, then a locker or spool is bad mmmmkay??? unless its like an air locker where it can be opened for street and locked for track.
    Oh and Norbs, Ive never head of the F series being used in hiluxes... I thought it was only G series due to the carrying capacity??? (note, I am not an expert on hiluxes, so could be wrong on that one)
    Also, if you want that 18RG to sing, then supercharge it, as torque is what will make you drift, not power... in fact a bombed up aspo 18RG wont have a touch on a basic supercharged one even if the max power figures are identical. If you want to do anything other than drifiting, turbocharge it, but seeing as your a dori dori sensei, supercharger is your friend... and the T series will quickly die under drifting, as it is quite punishing on diffs.
    Do you mean, like this?
    http://www.toymods.net/forums/showthread.php?t=24510
    ([][][]II--LT--II[][][])
    Victoria, Mt Macedon
    OK, there is plenty of shit being thrown in this thread, some of it justified, however on hopefully a more useful note:
    - You can use the stock T series to begin with. The drum brakes will be fine as the handbrake works very well on these as long as it is properly adjusted. Weld your stock centre or invest in a good LSD. An AE86 LSD to suit the small (zenki) axles will fit.
    - I drifted for 3 years on T series diffs and regard them as consumable, however they were all $20 from the wrecker jobs, if it's properly setup it should last far longer.
    - You can add ST141 Corona discs to your stock diff, though these will not have much if any effect on your driftability
    - F or G series diffs will be indestructible, but require the usual mods to make them fit. Not worth it at the moment I'd suggest. Get you car running and on track, then see what, if anything needs upgrading.
    Hen
    It's the front diff, that's how all us MA61 owners have Truetracs
    User Conversion King
    NWA
    if your looking for a killer handbrake then mount a second calliper to each disk and run hydraulic. a bit of extra weight in the back but the benefits would be far greater.
    hilux front diff is F series
    hello
    Makes sense then
    Hen
    Exactly! What's the worst that will happen? You could break the stocko and have to replace it. Meh...
    I would suggest if it's nicely lubed and good condition diff then you will be surprised at how long it will last.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    Given the abuse the drivetrain cops in a typical drift car, I wouldn't rate a T series lasting very long. That said, you don't have much to lose by giving it a go - provided you don't mind paying for a tow home.
    As I siad, I have drifted a T series diff for the last 3 years. I've broken two pinions and 3 axles (from memory). Those 3 axles had a reason to let go too, one was a burnout on hot sticky rally tyres, and two were on the same day while running tyres that were too big.
    So if you aren't silly and stick to tyres no bigger than 205/50R15 or 195/55R15 then things should be ok. I found the diffs that broke pinions got really noisy before they went too, so you had fair warning.
    Also consider that Josh young still runs a T series behind his 1UZ, and it has lasted at least one (probably more by now) event.
    Hen
    The Supreme Backyard Mechanic
    can only imagine how much longer it will last....
    i'm running a hilux diff in my ae86, but that's only cause i'm going rotary
    By The Witzl in forum FAQ
  2. ST141 rear disk brake upgrade - RA23
    By celicaboy_2000 in forum Tech and Conversions
    Last Post: 08-09-2007, 10:19 AM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
