if the air was still and fuel perfectly mixed, you would only need 14.7 times the air of fuel to burn all the fuel.
but, in high speed environment, combustion is not complete. ie, you make CO instead of CO2.. if you have 14.7 ratio, then you have O2 left over. part of reason for 12-13;1 is to use up more oxygen? (ie, increase chance of using more O2 and generate more heat.. the unburnt fuel could slightly add to the volume of gas and help a bit)
another part is cylinder and charge cooling?
another part is to cover up mistakes in timing ignition?
another is to cover for hotspots in the cylinder...
i think you may find that tuners don't trust their skills.. are aren't skilled enough.. or simply want to protect their pocket from busted engines... by tuning rich.
direct injection and more modern combustion chambers mean leaner mixtures are safer.
with stratified mixtures, very lean, like 17:1 or 20:1, can be achieved.
			 AFR's why tune so rich??
 If a tuner works mainly on Subaru's they're usually pretty cautious running anything not in the 11's.
