Page 3 of 3 FirstFirst 123
Results 31 to 33 of 33
Thread: AFR's why tune so rich??
    Junior Member Backyard Mechanic Rhyno's Avatar
    Jan 2010
    NT
    Default Re: AFR's why tune so rich??
    Hey Worldwalker,
    As far as I understand the BEST way is to measure AFR with an individual Wideband 02 sensor, installed in EACH exhaust primary pipe; that is one per cylinder about 2 foot down from the cylinder's. In a real world situation this is quite an elaborate and expensives set up, and I imagine most tuners wouldn't be able to tune it.
    So the best normal way is just one wideband where your exhaust mani joins up to the tail pipe.
    When I was learning the basics I found this very useful, very infomative video's with graphs. Should answer all your questions
    Innovate Videos :: Engine Tuning Resources
    Its worth making a cup of coffee before clicking through, they go for a few minutes.
    In particular this video: sniffer
    And this one was pretty good too: Innovate
    Hope this helps!!!
    Diserter Domestic Engineer
    vic
    Great thats the info I was looking for. I've spent the weekend on google and all I can find are a lot of people trying to sell me stuff and a lot of contradictory "evidence".
    Forum Contributor Domestic Engineer
    OST
    I'm not sure on specifically head porting, but from what I've seen, and my tuner has said the same thing, the more efficient an engine is at actually getting a complete burn, the less timing that it needs to make power. Greater efficiency = less time to do the same job. I imagine this is true with getting complete evacuation of exhaust gas etc in your porting case.
    The theory can sometimes be a false economy though. Ie, I was mucking around in the shop when he did some back to back testing of a turboed engine before and after fitting a thicker headgasket to drop the compression from 9.8 to around 9.3:1 (IIRC). Although in (really really simple) theory the high comp engine should have been more efficient at a given boost pressure, the act of lowering compression (without raising boost) and dialling in more timing actually made more power everywhere, and was a lot less critical of AFRs in peak torque. With then running leaner in the period prior to peak torque, which was not possible before pinging with the high comp, even more bottom end power was made.
    The fact that he did this without a second thought suggests he has seen it plenty of times before.
  1. 3S-GE setup Factory RICH @ High RPM ?
    By abently in forum Tech and Conversions
    Last Post: 24-07-2007, 01:25 PM
  2. 1ggze running rich, no idle controll
    By 1jzracing in forum Tech and Conversions
    Last Post: 07-06-2007, 03:45 AM
  3. Running rich?
    By joey in forum Tech and Conversions
    Last Post: 26-02-2007, 07:42 PM
  4. 4agze running very rich / fouling plugs
    By Necros in forum Tech and Conversions
    Last Post: 03-02-2007, 04:19 PM
  5. Rich 1JZ - Jaycar DFA, Apexi SAFC or ... ?
    By BabyZ in forum Tech and Conversions
    Last Post: 18-11-2006, 05:46 PM
