Results 16 to 18 of 18
Thread: fuel pump relay in ga70
    Default Re: fuel pump relay in ga70
    On the wiring diagrams I have for my car, if you pull that relay out, you loose power to the things I mentioned I'm pretty sure.
    Will check again later
    Edit: As for that power, I haven't noticed mine heat up, but again, I've never gone and out and touched the resistor afterwards.
    From electronics and electrical knowledge, it's a bit of heat that would build up, and you'd want some air flow.
    You may get away with it under the dash with a computer fan on it, with a good supply of air coming.
    But seriously, I'd just put it in the engine bay somewhere.
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
    Junior Member Backyard Mechanic Hash_ra23's Avatar
    AFM's powered off ecu i thought..
    Okay, it is only the pump that's after the relay.
    Just looked at diagrams again, sorry about that.
    And the airflow meter is powered via the EFI circuit, and is grounded via the ECU.
    My Dead Supra...
  1. Picking Best Fuel Pump..!
    Last Post: 10-09-2007, 03:15 PM
  2. Fuel Pump problem
    By Talasas in forum Tech and Conversions
    Last Post: 30-05-2007, 05:58 AM
  3. Fuel cooler / fuel temp
    By Pearce in forum Tech and Conversions
    Last Post: 12-05-2007, 07:55 PM
  4. MS85 Fuel Pump.
    By Brad-KE35 in forum Tech and Conversions
    Last Post: 31-03-2006, 09:12 AM
  5. Mounting fuel pump (intank)
    Last Post: 24-01-2006, 09:49 AM
