Results 16 to 17 of 17
Thread: HELP!!! 4age 100kw major problem
    Default Re: HELP!!! 4age 100kw major problem
    Im betting Key way too Irally. If tis worn it'll slip and throw your shit outa wack.
    Why would it be headgasket or leaks if he's clearly having pulley problems.
    Its like saying, "i have a flat tyre", then the wife turns around and says, "ill check the battery"
    Steve
    Junior Member Domestic Engineer mic*'s Avatar
    Quote Originally Posted by fkn16v
    Steve
    Umm, because of compression test results...
    They sound pretty whack tho... Do it again with a different instrument or get someone to do it for you... Not saying your wrong but to be sure coz 140 - 225 is a massive range for a motor that will actually still run - and 225 is ridiculous.
    If crank pulley is out of whack with cam, then dynamic comp could be affected but you would expect it to be consistent across all cylinders unless your cam has a big twist in it
    meh...
    Last Post: 17-06-2008, 08:53 PM
  2. 4AGE 100kw smallport turbo rebuild
    By BoostBoy in forum Tech and Conversions
    Last Post: 07-05-2007, 10:24 PM
  3. 4age tech question?
    By pro-16t in forum Tech and Conversions
    Last Post: 30-04-2006, 10:42 PM
  4. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 04:51 PM
