Results 16 to 30 of 47
Thread: Toyota V6s?
    Default Re: Toyota V6s?
    it's in the conversions forum
    someone say 2t-ze? Automotive Encyclopaedia gerald1's Avatar
    South Australia - ADL
    http://toymods.net/forums/showthread.php?t=18875
    i was shown the link the other day, its an awesome build!
    ta22 Green with cream vinyl roof, 2t/3t hybrid with a few go fast bits on + 5 speed.
    i've also wondered.... what fwd MANUAL gearboxes can be used on an MZ and a VZ engine?
    Does anyone know?
    google-edit: I just did a little searching... looks like an SW20 3SG gearbox will bolt up to the 1MZ engine, with only a few non-essential bolts missing.
    This is totally the next project for me. Without a doubt. I want a V6 corolla.
    The original gearboxes on most V6's are an E153 I believe, but some Celica and MR2 owners have used S-series gearboxes, eg S53, S54. Weaker, lighter, but probably the easiest to use for a conversion.
    yeah if im going to put a 1MZ-FE into my AE92, i'd probably want to use the lighter gearboxes in preference to a heavier E153 box with reversed selector (i havent even seen how to reverse the selectors... im sure its simple enough)
    of course a 1MZ in an ae92 might be a little bit toey, and thus kill an S53/54...... but them's just learning curves
    Of course, none of this will happen for quite some time yet
    VZ engine series FTW! Grease Monkey Timma's Avatar
    May 2006
    If you do this witzl i'll want a ride for sure! i'd be worried about the torque killing the s53 s54 boxes
    vzv21 camry 2vzfe v6 - aka mr burble or white one
    i think a good condition S54 with a 1MZ-FE would be fine, the S54 seems to be able to handle 3sgtes in FWD format with just the usual gearbox problems.
    this is a pretty cool idea, V6s arnt to bad..
    there is forum member with the sw20 V6, i was wondering what gearbox he was using.
    What is autosalon? Sounds kinda homo.
    Quote Originally Posted by tooch
    It's extremely homo. Basically a whole lot of sh1t cars, with ugly wheels, and a lot of 16-20 year old rockstars with trendy mullets and gay shirts.
    Slayer Of Toymods Wookie Slayers
    Been reading up on the 3VZ, the sound like they have some pretty tough internals. Anyone know if the 2VZ is the same? Ie just as strong internals? Cant find as much info on it....
    If I go 3VZ, i can only go NA, if I go 2VZ I can go FI.... decisions, decisions!
    Toyota Car Club (Qld)
    since Karl has other priorities right now, and fair enough too, it's safe to put this up for all to see.
    I found this during my my weekly Auction browsing...
    http://www.manheimfowles.com.au/find...rm=view_detail
    certainly looks like a good conversion contender to me with that rear end damage.
    Junior Member Backyard Mechanic pAuL's Avatar
    yes the 3vz has strong internals, but ive heard about head gaskets ala 7mge.
    im not sure what kind of internals are in the 2vz, but it seems like a strong engine
    Current - 2006 Colt Ralliart 100.2FWKW@6000rpm,
    Past - 1988 Toyota Camry V6 (Sold) (VZV21) 117kw@5600rpm, 1994 Lancer Station Wagon Executive (sold) (86kW+@6000rpm), 1986 Corona S (sold) (73kW@4800rpm), 1990 Cressida GLX (BHG) (142kw@5600rpm)
    yeah i'd love to buy a 1mzfe right now, but i do have other priorities.
    It's definitely on the cards for next year though
    Forum Sponsor Conversion King
    Quote Originally Posted by sillycar chick
    wouldnt waste time with a 2vz as they dont have the good internals (you could spend the dollars to build one if you wanted FI)
    id go 3vz or 5vz, the 5vz is 3400cc and came out rwd from the factory (meaning easier to setup) but they dont like to rev as hard as the 3vz (nothing cams wont fix)
    both these engines are strong as from the factory (minus the earlier HG probs) so i guess its a question of do you really want FI or a tough NA motor?
    linden
    ps, done a fair bit of research on them but chose to rwd a 1mz instead. reason: because it hasnt been done yet
    it's also worth noting that the MZ series engines are hard to use in RWD format, as the starter motor is mounted the opposite way to normal (meaning it goes towards the gearbox side of the flywheel, and not the engine side of the flywheel as on most other engines.
    If you're not too brand loyal, RX-7s mount the starter the same way. So, with an adapter plate you can use an rx-7 (strong), or mx-5 (close ratio) gearbox.
    Not a simple conversion, but definately has potential.
    Here is a page detailing mounting a FWD V6 into an mx-5. Similar challenges.....
    FYI GiantTomato developed an adapter plate which attaches a VZ series engine to a W5x transmission. If you want a manual behind your V6 you should have a chat with him.
    I did find that Norbie, if I end up getting a VZ i will hit him up
    Looking like im going that way anyway....
    Anyone know how much the 3VZ weighs, and the 1MZ? Having trouble finding something other than vague comments around the net...
    Found a good list but doesnt have the v6s on it
  1. Toyota R Engine History
