Results 1 to 6 of 6
Thread: TA22 rear wheel bearing size?
    Default TA22 rear wheel bearing size?
    How's it,
    Anybody know the correct part number / size of the TA22 rear wheel bearings from CBC or SKF?
    Jordan
    Default Re: TA22 rear wheel bearing size?
    Should be the same for all Celicas that have the T series diff. So if you have a catalogue then look for anything "Celica 1971--1980".
    I will see if I can find an axle at home over the weekend if none reply with a number in the mean time.
    Regards
    Rodger
    south austraila
    Some early TA22's had a smaller axle bearing......
    But rang local auto shop & they say all the same..
    I must of got an odd one..... maybe it was a "S" diff in a TA22..???
    Project: '82, GA61 XX
    Junior Member Domestic Engineer TA22 GT's Avatar
    the part number for a TA22 from 12/70 to 04/73 is 04421-20010 for the bearing which is NSK and the seal is 90311-42055
    Simon
    south austraila
    I was at the wrecker the other day, & there was an early TA22, with axles out..
    Some early TA22's had a smaller axle bearing...... 62mm diameter
    & late TA22's had a larger axle bearing...... 72mm diameter
    The difference between "D" and "T" series rear ends, would account for the different bearing sizes.
    cheers Chuck.
    MS51Crown Coupe,
    By The Witzl in forum FAQ
  2. MA61 Part Numbers & General Infomation
    Last Post: 27-03-2013, 01:31 AM
  3. Suspension for dummies
    Last Post: 13-09-2007, 08:38 PM
  4. Old RWD Wheel Studs / Nuts Size
    By Screamn_Sleeka in forum Tech and Conversions
    Last Post: 21-06-2006, 05:51 PM
  5. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
