Results 1 to 7 of 7
Thread: Turbo Manifold Studs
    Junior Member Grease Monkey medwin46's Avatar
    Default Turbo Manifold Studs
    Hey all
    I need some decent studs to thread into my manifold to bolt the turbo on with. Apparently normal studs just wond cut it, i need ones that will survive the extreme temperatures in there.
    SYD
    Default Re: Turbo Manifold Studs
    Hey mate saw no one has posted and thought i would see if i could help, if standard studs wont stand up to the test cant you get some high tensile studs?
    Graphic Designer Grease Monkey Petes77celica's Avatar
    I was actually talking about this to the bolt place the other week about this alot of places dont have engineering studs as there very difficult to get a hold of. As i had to shorten a few of mine as they hit on the manifold but how ever they did suggest getting bolts and removing the head of them but i wasnt really keen for that wat type of motor is it you may find out that something like 1JZ-GTE or similar studs may be the same but im not sure.
    Pete
    1977 RA23 LT CELICA
    Here it is right here http://www.toymods.net/forums/showthread.php?t=23121
    New Zealand
    what engine is it?
    i havnt noticed any differences between n/a engien studs and turbo ones...
    then again iv never looked
    please, no more PMs!
    just get some exhaust manifold studs, from any exhaust shop, what i use and its fine.
    blake
    victoria
    Id say if your manifold will go along time before the studs pop. I just got em from repco and no issues yet.
    sir Grease Monkey
    tasmania
    i use 12.9 grade capscrews , bullet proof and you can turn the head off and thread the end and you have studs that are arp quality. cheers bigwad
  1. Replies: 3
    Last Post: 13-04-2007, 05:38 PM
