Results 1 to 15 of 16
Thread: Microtech on 2JZGTE
    Western Aus
    Default Microtech on 2JZGTE
    Hey all, ive got a microtech to wire up to a 2JZ here, only prob is, 2JZGTE diagrams from microtech, i cant find any.
    i have a 1JZ wiring diagram infront of me, its for a GTE.
    as far as i can tell, pretty much everything is exactly the same, or will i blow shit up?
    if anything is different, can anyone explain why?
    rep will be given.
    Cheers.
    Elmo.
    Default Re: Microtech on 2JZGTE
    Yes wiring etc should be the same between the two engine.
    Injectors - doesn't matter which way you wire them.
    Powers/fuel pump - there as per diagram
    TPS/Air/water temp sensors - as per diagram
    Crank sensors - these should be wired the same as the 1JZ, but sometime are a trial and error thing.
    Coils - same... depending on what your using anyway.
    The only part which could cause problems for you are the crank/cam sensors, but these won't damage the computer if the are wired up wrong.
    CHECK IT OUT HERE
    Western Aus
    ok, cheers, ill work it out when we get the motor running.
    sorted
    Elmo.
    Junior Member Backyard Mechanic byteme's Avatar
    W.A.
    *hugs eldar* man your the best....but no bum sex for you
    cant wait to get this thing going.
    Hamgatan says:
    i pwn my momma
    wa
    Shit your wiring yours up already
    I better pull my finger out
    W.A.
    hahah na just sorting the loom out !
    Hamgatan says:
    i pwn my momma
    W.A.
    your slack ez....
    Eldar is defiantly the opposite of slack.....
    Together you guys even out
    oohhhhh group hug
    So when can we come listen to it running ezy e??
    W.A.
    when i get the new shiny bits from the states on to it !
    Hamgatan says:
    i pwn my momma
    W.A.
    hahahaha no really. form over function... well bling yes if it means my engine wont explode.....
    ahh i spose i am arnt I.... im still not buying the crown
    Hamgatan says:
    i pwn my momma
    jetpilot Automotive Encyclopaedia 1JZ.747's Avatar
    if you get stuck, send me a pm and i will give you details on my buddy at microtech tech support.
    1jz and 2jz ltx12s's come with the same wiring diagram so you should be fine anyway mate.
    8.3 et PB 169 MPH PB
    Western Aus
    yeah ive worked the majority of the stuff out, just trying to figure out the finer bits, ill sort it out!
    Matteh, you should know me better than that, i am teh slacker than ez.
    Elmo.
    you 2Jing your 70 ez?
    hey shane...can your buddies get me an LTX12S? the older one
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    i can get ltx12s with seperate x6box or i can get the ltx12s like mine which has the ignitor in built
    yeah the one with the internal ignitor...like what I put on my soarer...just out of curiosity what are they worth?
  1. Microtech Or Autronic???
    Last Post: 18-06-2007, 04:44 PM
  2. MicroTech???
    By iSOARu in forum Tech and Conversions
    Last Post: 04-02-2006, 10:20 AM
  3. Microtech guru - Delco Idle Motor
    Last Post: 23-01-2006, 03:45 PM
