Yes wiring etc should be the same between the two engine.
Injectors - doesn't matter which way you wire them.
Powers/fuel pump - there as per diagram
TPS/Air/water temp sensors - as per diagram
Crank sensors - these should be wired the same as the 1JZ, but sometime are a trial and error thing.
Coils - same... depending on what your using anyway.
The only part which could cause problems for you are the crank/cam sensors, but these won't damage the computer if the are wired up wrong.
... 11's soon
