Results 16 to 28 of 28
Thread: Slow Ignition Advance
    Honest To God Engineering Grease Monkey silent_witness's Avatar
    Default Re: Slow Ignition Advance
    Sounds like it could be anything.
    If its a problem while accelerating, it wont be the vac advance.
    Look elsewhere.
    Cheers will do
    [W.W.J.D] What Would Jesus Drive? Old Rolla's
    Top Gear = Jeremy Clarkson
    TG = JC
    The God = Jesus Christ
    The God = Jeremy Clarkson
    Quote Originally Posted by allencr
    There is no problem, just you noticing something that you didn't/don't understand.
    I see no reason for having a 'vaccum advance' except on stock daily drivers for average/normal people.
    ....well isnt that what my car is.....a stock daily.......
    TG = JC
    plenty of reason
    in my experience cruise fuel economy can improve between 10-20% and less throttle is required to maintain cruising speed
    Quote Originally Posted by SeptemberSquall
    plenty of reason
    Agreed.
    People who disconnect them and then claim their car "goes harder" need to learn how to tune ign timing properly or find a new mechanic.
    Feb 2007
    Timaru
    We always remove vacuum advance on race dist's as race cars dont worry about fuel economy at cruise etc etc,
    and we run the mechanical advance quite high so you dont want vacuum advance adding in any more.
    If you just unplug the vacuum line on a normal car, you should'nt notice too much of a difference apart from fuel economy and cruise driving.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    another questions guys, on the line coming BACK from the vaccumm theres a 3 way joint, and on the line that runs to the carbie it has a sorta one way valve.....whats it for?? negative pressure??
    TG = JC
    Quote Originally Posted by DX20VT
    agree entirely
    two different applications at issue here
    Quote Originally Posted by silent_witness
    Do you try to work these things out for yourself at all, or do you just jump on here and ask?
    Asking things like this when 5mins of thinking/tinkering on your part would probably answer the question will give you a bad rep... a problem when you do have a serious question you want to ask.
    RTFM?
    you do have a manual for the car?
    did you adjust the distributor timing after replacing the points?
    ... and gap the points properly?
    yes and yes.....i think it looks 'slow' because of the way i thought the vaccumm workd, but know having been told its wrong...it advances but....a good second after i give it a boot...so i dont know...
    TG = JC
    Its probably ok.
    Check the weights in the bottom of the dizzy too... make sure they can move freely.
    These do have a big effect on performance, and can sieze up easily.
  1. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 02:42 AM
  2. Ignition Fundamentals..... what's in a spark???
    By RAd28 in forum Tech and Conversions
    Last Post: 14-06-2009, 07:29 PM
  3. 1JZ problems, wont rev, Please help ASAP!
    By ReQuieM in forum Tech and Conversions
    Last Post: 11-07-2007, 02:54 PM
  4. Replies: 0
    Last Post: 20-07-2006, 01:18 PM
  5. 18R-G ignition curve needed
    By pilot in forum Tech and Conversions
    Last Post: 16-03-2006, 11:11 PM
