Page 3 of 3 FirstFirst 123
Results 31 to 36 of 36
Thread: Puttin a Rear swaybar into a TA22 Help!
    Forum Sponsor Conversion King
    Default Re: Puttin a Rear swaybar into a TA22 Help!
    check on whitelines site im pretty sure they have instructions for aftermarket bar fitting.
    or you can search members rides, but you'd be to unmotivated for that option
    slackarse
    linden
    Quote Originally Posted by rob
    welding my arse
    drill 2 holes and the rest bolts up
    shouldnt have to drill holes, as they utilise the uper trailing arm bolt.....
    ^ ^ ^ blake speaks the truth!
    I have a Selbys rear sway bar and that's how it's mounted.
    deepdishfactory
    ahh forgot we were talking about a celica here not a rolla
    As I said there is always more than 1 way to skin a cat. The bar you have needs to be mounted to the chassis and will require some brackets bolted or welded to the chassis rails.
    There are alternatives though. It sounds like the whiteline bar is more of a bolt on solution or even easier is the bars that just bolt to the trailing arms. If you want to use the bar you already have then you will need to do a little bit of work. Personally I prefer the type that you have as it is a directly ties the chassis roll to the diff and is a good solid solution.
    ****** Backyard Mechanic 79GT's Avatar
    great info guys. did you end up getting it in and going or what. which leads to my second question. what sorta of effect did it have on handling performance. in my head it seems like it would make a HUGE difference, but i may be getting over excited lol. let me know guys, looking to get one of these into my 22.
    Cheers Jamie
  1. TA22 rear window rollers
    By RiceburnaGTV in forum Tech and Conversions
    Last Post: 18-05-2021, 04:31 PM
  2. AE82, AE92 and AE101 Brake Upgrade Guide
    By The Witzl in forum FAQ
