Already started directing them here.Originally Posted by jezza323
Good thread..I found the same thing with my 21R-C.. in short you can't make power, but you can free up power.. eg. port matching the inlet manifould to the head, this will reduce Eddy currents, & free up the air flow into the head..
Project: '82, GA61 XX
Daily: DC2 Integra VTiR :: 96kw @7300rpm - 132nm @6300rpm
Techno Toymods | Beninca Dyno Day Results 10/9/05 | GOR Cruise '06 | My Photography and Illustration
A 5 litre V16 will have more frictional losses but will have more valve area to capacity and has the potential for more power.Originally Posted by gianttomato
300 ft/sec has been used as an optimum figure in pure race engines for many years. Production based race engines have compromised port designs and a theoretical 300 ft/sec may not be optimum due to other factors.
Keith Duckworth, founder of Cosworth, once stated "turbo's are for people that can't build engines"
When you start looking for maximum power a turbo engine will cost as much or more than an n/a engine.
maybe that should read co-founder of cosworth rms![]()
good thread here,
unless you mean something other than what im thinking, nonsense!Originally Posted by rms
EDIT:
as per what Ed says below, i agree, but how do you define what an engine's potential power is?
he means to fully optimise and capitalise on a turbo configuration for absolute maximum output (not just 'more than') is harder and more expensive than an NA engine
../delete/ban
tech moderator
you establish the maximum operating tolerances for all your components. ie rpm and piston speed, combustion chamber size and possible valve and port size. port potential and orientation. turbo turbine/compressor map details... blend it all together, and stretch every component to its sustainable limitOriginally Posted by shinybluesteel
../delete/ban
tech moderator
sweet ed, thanks!!!!
+rep
That's gotta be the longest guid i've ever seen on the net.
And considering how difficult a subject it was covering it was pretty complete.
The man knows his shit!
kudos.
+rep for the postOriginally Posted by ed_jza80
but you should be neg repped for forgeting that the sm4 has an injector calcthat will allow you to change injectors mithout the need for a full tune (more of a tidy up).
and without your comp ratio and cams mos' maps will need alot of retuning anyway.
linden
Originally Posted by WHITCHY
just want to try and not bed-in the engine on a virgin tune... a good base map will get it out of the woods for the first 10mins will the rings bed
../delete/ban
tech moderator
very true, but with a competent tuner and your knowledge of the engine build and an sm4 he should be able to rough up a map to suit without even starting the engine.
please tell me your not planning on trying to run this thing in with no load on it?
linden
oh forgot you went gapless, honestly never had experience with them so i cant really comment.
Lets for a moment forget that the IS has a returnless fuel system....
The SM4 doesn't have a setting for the type of return system (afaik), so while tuning it on the IS fuel system will give you the VE table, it won't be very useful.
To get the closest tune on my engine with your manifold we'd need to rig a return type system in the bay using a 5L jerry can - don't worry, I've done it before, will be fine
Mandatory on topic content - what would one expect in terms of power increase changing *only* the manifold/throttle bodies?
Mos.
Big budget build....might want to "invest" in $1K engine dyno tune?
Just putting it out there.....
2JZ went from 115 to 148 rwkW.Originally Posted by Mos
