Results 46 to 52 of 52
Thread: 20v sounds like a diesel
  1. #46
    New Zealand
    Default Re: 20v sounds like a diesel
    yep $400 nz, including freight etc.
    no seafreight, as are in the country.
    p/ns
    BLACK TOP
    belt 13568-19185 $45
    tensioner pulley 13505-16030 $55
    hydro tensioner 13540-16010 $55
    VVT pulley 13050-16020 $964
    SILVERTOP
    belt 13568-19035 $45
    tensioner 13505-16010 $55
    VVT pulley 13050-16010 $1169
    have included NZ rrp for fun
    to use ST tensioner on BT you need the oil pump
    NEVER forget to change the BT tensioner when changing belt.
    and yes.... please email not pm. PMs are not good for keeping track of things!
    please, no more PMs!
  2. #47
    GameOn Backyard Mechanic Poggy's Avatar
    The plug on the frotn left hand side of the head just left of the exhaust manifold, get a wire off your battery postive and connect it to both wires on the solinod, the rattle shoudl stop.
  3. #48
    Low rep Grease Monkey
    is that all the parts you have 2 replace
    SILVERTOP
  4. #49
    New Zealand
    well i would do cam and crank seals as well.
    and water pump if it hasnt beem done recently.
    but yes, for the cambelt thats it
  5. #50
    if i get this cams would it fix the sound
    http://www.modyourcar.com.au/product...oducts_id=2433
  6. #51
    yes, the Toda inlet cam gear fixes the rattle, but you lose the VVT functionality with the Toda gear.
  7. #52
    but u should gain wif the new cams or just buy the stock ones wif the vvt
  1. Quick question re: turbo diesel
    By tangcla in forum Tech and Conversions
    Last Post: 15-04-2007, 01:04 PM
  2. Opinion : Using Diesel as an oil flush
    By Grega in forum Tech and Conversions
    Last Post: 27-11-2006, 04:30 PM
  3. 2L diesel pump seal replacement.
    By beterthenu in forum Tech and Conversions
    Last Post: 19-09-2006, 06:20 AM
