Results 16 to 30 of 51
Thread: No boost all of a sudden ?? How to re-attach actuator rod to wastegate??
    Toyota traitor Automotive Encyclopaedia GBC_069's Avatar
    Default Re: No boost all of a sudden ?? suggestions ??
    yeh as said, car was running fine before the coil went, and the engine died instantly when the coil shorted.
    yer - turbine spins like it did a month ago or whenever, still smooth.
    will definately check plugs - however it is strange that it will not boost at any rpm. if they were fouled, you would think that it would drive nice at low, then if fouled, clog up at high rpm maybe. yer still running emanage, hasnt been touched.
    fuel pump related possibly ? not pumping an adequate amount of fuel ? will not allow boost ?
    at the end of my tether with this stupid car.
    NOW - 2002 WRX STI - WRC Blue 180awkw @ dyno day 20
    WAS - 1991 GT4 GRP A no. 68 153awkw, 13psi @ dyno day 18
    WAS - RED ST162 JDM 86kw @ dyno day 12
    Quote Originally Posted by GBC_069
    Bah.
    There aren't many things that can cause you to loose 100% boost
    What you need to do is take the dump pipe off and verify that the turbine wheel is still there!
    Just because the turbo spins fine doesn't mean that there is a turbine wheel attached to the side you can't see
    Seeing as you are quite sure that there are no boost leaks that is the next major thing in line to check (As I see it).
    What is your vacc reading at idle? is it around 18-20mg? thats roughly what it should be. if it's lower (-15mg) then you will have some sort of leak.
    if your plugs are fouled(?) it will run like a bag of shit the whole time,
    plugs wont effect boost either.
    Plugs can limit boost, I wouldn't imagine they'd ever be bad enough to stop it altogether. My car would only make ~10-11psi when the plugs were REALLY f'ed up.
    I'm with the guys saying that I'd be checking for a turbine wheel.
    I didnt read the whole thread, but have you checked the wastegate acutator rod is still on the gate, this has happened to me and had me stumped for ages haha.
    mmmm ,jus wat i needed to hear aye ! lol well lets hope its not that !!!
    ummm , yer i cannot see any leaks or anything, vac reads like 30 - 40 at idle
    will go pull off the dump lata on, hopefully she wont be too seized, will let the old WD do its work.
    so can the turbines fall off completely can they ?
    haha hell yeah, but lets hope its the gate rod , no way could fouled plugs stop 100% boost, and it would drive like shit 100% of the time until you gave it a boot full and possibly "unfouled" them.
    lets hope nick the turbine didnt go on a holiday !
    man you having sum badluck bro
    What is autosalon? Sounds kinda homo.
    Quote Originally Posted by tooch
    It's extremely homo. Basically a whole lot of sh1t cars, with ugly wheels, and a lot of 16-20 year old rockstars with trendy mullets and gay shirts.
    Slayer Of Toymods Wookie Slayers
    hahah yeah its common to see some of the drag cars out at the track shoot the rear wheel out the zorst
    not sure if its been mentioned yet but have you checked the turbine wheel too see if its still attached?
    lol
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    lol someone didnt read the thread
    Quote Originally Posted by Jorrs
    my sarcasm detector is in the shop being fixed
    fixed....
    i ll try the wastegate actuatator , thanks berad
    yer shit i really hope its not the turbine wheel, there are no reasons to suggest it would fall off, the car is running 8pnd, turbo was rebuilt with a steel wheel 40k ago !
    Also check the wastegate isn't jammed open.
    Actuator may not be operating correctly.
    Connect up an air compressor and see if it opens.
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
  1. boost creeping issue..
    By renxun in forum Tech and Conversions
    Last Post: 11-03-2007, 08:32 AM
  2. Turbos 101
    Last Post: 24-01-2007, 07:23 PM
  3. Autronic SMC boost control help
    Last Post: 27-08-2006, 10:16 PM
  4. Boost Leak Tester
  5. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 03:53 PM
