Results 1 to 8 of 8
Thread: 1uzfe Into Mx83 ??
    Junior Member Backyard Mechanic sunkloto69@hotmail.com's Avatar
    Exclamation 1uzfe Into Mx83 ??
    Hey guys just wondering what has to be modified, and what i need to purchase ?
    i searched all the old threads in various titles and couldnt find instructions on what will have to be changed, thanks, Dave
    currently not piloting a toyota
    Default Re: 1uzfe Into Mx83 ??
    Custom headers (or modded ones), custom mounts, front sump, custom tailshaft.
    Everything else as per any other conversion.
    Montrose
    Exhaust, mounts and front sump, and you can make use of the original tailshaft if you so choose, depends what gearbox you use and where you mount the engine.
    Ecu body wiring plug on the mx83 plugs into early Crown !uz ecu . Will need repinning though. Sump is not front mount
    Jealousy is a curse
    A340E trans with Celsior bellhousing and a celsior converter
    is there any mounts that will work or do they have to be custom made, what about trans mount and what sump will it need, this car will be going through regency so it needs to be spot on
    Did you even read half the things that people said ?
    yes i did..... but i asked what ones.... i know the exhaust has to be modified, but other people have surely done this conversion a few times, i wanted to know if anyone had learnt of interchangable parts.... saying the sump needs to be changed doesnt help when i dont know what engine it needs to come off of. i havent done a engine swap like this before hence trying to get all the info i can get on it.
    Front sump as stated twice above.
    I have not heard of anyone being able to use factory steel mounts to do the conversion.
    Browse toyotacressida forums, a couple of guys have done semi writeups on the conversion.
    There have probably been about 6 or so people I can think of who have done this, and all have done it slightly different to each other. Some have modded factory headers, others have built extractors. Some have used 7M auto, some have used 1UZ auto with factory donut, some have used 1UZ auto and modded it to fit 7M slipyoke.
    Thus far there is no 'correct' way to do the conversion.
  1. Castor Rod Bush Replacement on MX83
    Last Post: 23-11-2016, 03:41 AM
  2. 1JZ into MX83 using JZX90 Halfcut?
    By jap-taxi in forum Tech and Conversions
    Last Post: 04-12-2006, 10:36 PM
  3. mx83 1uzfe box help
    By DenZel in forum Tech and Conversions
    Last Post: 26-03-2006, 10:07 PM
