Results 1 to 11 of 11
Thread: Anyone got a pic of a 2JZ GE ECU?
    stunt dog Backyard Mechanic Esteban's Avatar
    wa
    Question Anyone got a pic of a 2JZ GE ECU?
    I'm trying to determine if the 2JZ GE ECU has the same AMP connector as the 2JZGTE connector. Buying the AMP PAIRMATE connectors in small quantities is suicidal, so if they're the same on the GE's that could be a much cheaper source.
    No they aren't the same as the 2JZGTE vvti, the 1JZ anything etc etc. I've checked.
    This is what the GTE versions look like:
    TIA
    quarantine is gay Backyard Mechanic rustyP's Avatar
    Default Re: Anyone got a pic of a 2JZ GE ECU?
    Spotto aristo floorpan!
    (*free bump*)
    wa
    Spotto all my stock speaker wiring has been replaced with oxygen free stuff. Albeit in the most hideous, tangled, unsupported way possible. Unsure if I still have stock speakers, although I haven't tried the stereo yet. I do know however, that when somebody stole the aftermarket alpine amplifier from the sub in the boot, they just cut the wires to the sub, and left the power straight from the battery dangling uninsulated in the boot...
    Looks the same as my Supra 2JZGE ecu connectors . Also the same as various 1UZFE ecus
    Jealousy is a curse
    wa
    Hrm, I have a 1UZFE, that's one I didnt check, will do that today
    Madmont, you wouldn't happen to have a pic would you? :-)
    takai should have one of these sitting in his garage...
    give him a kick in the bum to host some pics
    Yea I've got one in the cupboard at home, if nobody has posted a pic up this arvo I'll grab one for you.
    Which connectors are you after?
    I think the body loom connector (which I need) is about $30 from Toyota! I assume you'll need pins but I'm guessing it will be possible to get them from something else...
    An option?
    Jan 2007
    This is from a manual '94 supra 2JZ-GE.
    wa
    Fuck yeah, thanks NAT!
    Jan 2007
    No probs, need any other camera angles, details i can help you with let me know.
  1. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 08:10 AM
  2. 4agze fault codes & diagnosis + Pulley
    By Poggy in forum Tech and Conversions
    Last Post: 01-05-2007, 11:11 AM
  3. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 07:31 AM
  4. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 11:17 AM
