Results 1 to 15 of 22
Thread: help / mx83 / 2jz / cruise control *now fixed*
    Default help / mx83 / 2jz / cruise control *now fixed*
    hey i have this mx83 cressida with a 2jz in it, and the cruise control doesnt work anymore.
    i know southo has his fixed but the asshole that fixed it is only interested in financial reward to part with the solution (hardly the toymods way is it?)
    anyway i took it to toyota today and pade them muny!! (dont neg rep me) to get it fixed, Unfortunately i was short on time and they wanted the car for a few hours to fix it, but in the time they had the 'toyota technician' reckons that the TRANSMISSION COMPUTER isnt talking to the ENGINE COMPUTER!! even tohugh i thought they were one and the same box.
    also with the 2jz auto conversion one of the speed sensors is missing and you get that o/d light flashing, but a 1jz>mx83 conversion seems to have this same fault and cruise control works fine.
    also my tacho isnt hooked up but im sure cruise control doesnt need a tacho signal.
    any ideas what i need to do to get cruise control working? it turns on ok (dash light) but wont allow me to set the speed...
    Aug 2006
    Default Re: help / mx83 / 2jz / cruise control
    LOL jessie what the hell did you think a " toyota technician" would do
    I would neg you but im scared of the consequence's
    Pm ghostrider, he too had his fixed at the same time as southo i think
    He has a 1uz in a mx83 but i think it was a similar fix
    Not just a regular Backyard Mechanic ProjectSleeper's Avatar
    Both Ghostrider and I had ours done at the same time (yes, mine is 2J, his is 1UZ)
    I wish I could tell you exactly what was done. but I honestly have no idea.. he was under the dash for a few minutes only, and it was done..
    Afterwards, I pointed Mos in the general area that he was woirking on and Mos said "ahhh I think I know what it was" - but he never had a look..
    im going to visit cambelt on wednesday, he has his mx83 running and has a few ideas how to fix it, will keep this htread posted!!
    I'll be watching with interest, I assume the MX83 has a vacuum-operated cruise module like my MA61?
    From that diagram it indicates that it requires a SPD sensor from the ECU. And also the SP2 sensor from the gearbox (G-W SP2 in 2nd diagram)
    Now, im guessing that the SP2 sensor isnt hooked up, and hence its not working.
    ^ yes thats what i reckon too, but i thought it was SP1 that i was missing Mos's wiring kept everything else working. but i could be wrong it might be sp2 i am missing.
    btw where is the cruise control ecu located?
    My cruise works, car uses the 7M cruise control module though. Only have 1 speed sensor hooked up (dash I think). Unfortunately I can't tell you how, as the car came with the 1JZ already fitted and cruise working. Scrote (prev owner), Mos, or Sideshow might be able to help you out.
    244rwkw / 328hp @ 18psi
    Thanks to Dave (cambelt) my cruise control is now working!!!
    it is awesome and i bestow the blessings of rep to cambelt!
    if anyone wants to know the fix pls pm me for now and then give dave some of your rep.
    Cool, that sounds good. Good to hear its working again.
    Good to hear mate Why PM the fix? Just post it up on here so future people can search for it
    Montrose
    Default Re: help / mx83 / 2jz / cruise control *now fixed*
    Interesting, I've noticed several mentions of people having issues with their MX83 cruise control, but I never had any problem with mine. I'm running a 1UZ, auto, and Motec.
    Aye, you are probably just feeding it the correct signals.
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Are the SP1 and SP2 signals the same signal? As in, at say, 60km/h, is the voltage/pulse the same on SP1 and SP2?
    If it was the same, couldn't you just feed the signal you have (SP1?) into both inputs on the Cruise ECU?
    Heh, its not SP1. Much simpler than that.
    Infact im not sure why PJ isnt posting it, but ill let him decide on that front.
  1. ECU jzx100 pins
    By splatt in forum Tech and Conversions
    Last Post: 30-08-2011, 06:11 PM
  2. MX83 Cruise Control
    By TheDarkRaver in forum Tech and Conversions
    Last Post: 10-07-2007, 07:15 PM
  3. Replies: 4
    Last Post: 18-04-2006, 07:22 PM
  4. mz20 cruise control?
    By MZ paul in forum Tech and Conversions
    Last Post: 30-12-2005, 06:55 PM
