Page 1 of 6 123 ... LastLast
Results 1 to 15 of 83
Thread: my toy, old toy new setup
    casual user 1st year Apprentice
    Default my toy, old toy new setup
    justa qik post to let the world see my latest stupidity in my very tired and worn old drift hachi. i know i know, not another drift car but yeh conversion is, well differant....
    started like this....
    Shot at 2007-08-20
    then went to this.....
    Shot at 2007-08-20
    then had a hairdryer added...
    Shot at 2007-08-20
    got sick of killing 4a gte's at 180 - 200 rwkw so did this....
    Shot with Canon EOS 30D at 2007-08-20
    is an extremely time consuming conversion. we cut 60mm out of the firewall, used an ma70 supra tunnel and a w 58 box. now runs a pedal box and very rear mounted seating position with shifter linkage...
    hardest thing was learning how to drive it, surprisingly the handling was nearly spot on as it was, weight differance is there but barely noticable. biggest handling drama first time out was the brake bias setup on the tilton pedal box, once sorted the car was majic...
    Default Re: my toy, old toy new setup
    Were you drifting it at indy last year or had it on display it at indy, i remember seeing it there, or maybe i was to wasted to remember anything haha, an odd conversion considering the factory balance of the ae86, but good on you for trying something different and good to see it works well.
    yeh was a decision born from cost effectivness... built 4a motors are great but when you use 4 in 2 years the cost becomes prohibitive, so another form of motivation was sought...
    the 1uz is strong as all hell, and in stock form makes enough power to be comparable.. not as high a rwhp figure, but well over double the torque, and back to na drivability as well..
    is a very fun combination..
    That looks totally awesome!!! Would you care to post up as much detail about the conversion as i am sure you are going to get bombarded with requests, along with videos of how is sounds!
    Raastler Grease Monkey
    Good to see you're loving it again Josh.
    Would you mine sharing a bit on how it drives and handles ? Would be interesting to know. Specially with the mods to the tunnel etc to centre it as far back as possible
    Nice work,
    Saw this car at QR 2 weeks ago.
    Was stoked to see a 1u at the drift!
    that's just about my dream car right there... beautiful work!
    What sort of ITB's are they?
    well, where to start..
    we actually broke the camera at the crutial finishing stage when it was all coming togeather but i guess ill start tonight and update a bit at a time....
    we originally planned to drop it all in and not cut the chassis at all, after looking at some pics of , i think, sprinter trd's ,track version, we thought it would be a goer that way...
    once we sat it in there, we totally decided it needed to go back a fair bit to keep some semblance of handling in there. so out came the angle grinder....
    a few texta marks....
    Shot with PENTAX Optio M30 at 2007-08-20
    and a lot of angle grinding....
    and we ended up with a fairly sizeable hole in the car...
    from here we added a steel 1.6mm box section to bring the firewall backwards 60mm...
    and a tunnel trimmed and cut from a parts ma70 supra, seeing we figured a r154 clearance was big enough...
    and then..
    the result was quite a lot of room under the floor....
    as you can appreciate theres lots of photos and a lot of explaining to do, ill post more each night and answer any questions, but theres no way i can sit thru doing it all in one sitting sorry..
    we looked at two sorts of setup for the throttles, the first was an efi products set, and this set is actually 2 sets of silvertop 20v throttles, all packaged in a kit through the guys at A1 turbos in NZ. all these guys do is 1uz conversion bits..
    the efi products kit was a little flashier, but used the lower half of the factory inlet, and hence the inlet length was about 7-8 inches longer from the butterflys to the valves. we figured that being a 4 liter v8 in a sub 900 kg car already, we didnt need any more low down grunt, and the shorter inlet length is supposed to promote top end revability. we combined this with a set of custom made ( re home made) narrow diameter, short primary 4into 1 extractors, and the car susequently revs its tits off. happily sits at over 7000 rpm with just a hit of the loud pedal..
    pics of all bits to follow as the build pics progress..
    GET UP SOME BLOODY VIDEOS OF THIS IN ACTION!!!!!!!!!!
    thats nuts, love the ITB,s and must sound massively HORNY!
    blake
    Junior Member Backyard Mechanic TC1600's Avatar
    Feb 2007
    Awesome conversion, subscribed for Teh Story
    +repness
    Noice, good to see it done properly.
    who's "we" josh?
    it sounds like you had help building it!
    Josh in fact, built this all himself, in his shed at home.
    very impressive
    glad to see it works!!!
    (and it didnt kill the T diff!!)
    Go drifting...
    Junior Member Grease Monkey Intense's Avatar
    Josh is clinically insane, and this would have to be the coolest sprinter in the world
    Sa22c Series 1 rx7, 12a extend port, 900rwkw @ 93,320 rpm sold
    Ra65 celica hatch, 22re with 2.25" exhaust, 500Nm @ 27rpm sold
    Ae86, 4agze, 170Takumi Powers @ 11,000 rpm
  1. fuel setup
    Last Post: 12-09-2006, 09:24 AM
