Page 10 of 11 FirstFirst ... 891011 LastLast
Results 136 to 150 of 157
Thread: 2JZ-GTE into MZ12
  1. #136
    User Conversion King
    NWA
    Default Re: 2JZ-GTE into MZ12
    Werent MA61 diffs F series IRS??
    mz12=irs
    Have you checked that your thermostat opens properly??
    yep, even put in the one out of the 3RZ while the engine was out
    Is the AC booster fan coming on??
    there is no booster fan. ive got the hydro fan running at max speed and it moves a HELL of a lot of air
    hello
  2. #137
    Is the fan running at max speed all the time? Maybe it's loading the engine up too much?
  3. #138
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    bit of an update.
    the missing problem has gone away when i started using a mates ecu. i borrowed the ecu 2 days before i went to cairns and it didnt miss a beat the whole way. I racked up 900 odd km in total.
    ive since bought a supra ECU which hasnt arrived yet
    the gearbox is still going okay...
    i still have cooling issues though. a short while ago the hydrofan blade exploded and took out the MX73 radiator. i reinstalled the factory copper-tank Z12 radiator for the time being and it seems to show the same symptoms. i also tried relocating the number plate for the trip and installing extensive underbody sheilding to help air flow. it didnt seem to do much however
    most of the time its fine, the temp will sit where its supposed to. when the aircon has been on for a few minutes it seems to just tip the cooling system over the edge and the temp goes up.
    i also installed a stock MA61 3.909 LSD diff. its interesting to note the input pinion flange was different to the supra. i suspect it was a G series pattern.
    thats about it i guess
    out of interest did you just change the yokes over between the 2 diffs to get the g series yoke onto the f series diff?
  4. #139
    NWA
    yep its running at full speed the whole time. the relative load on the enging is stuff all. less then the AC compressor kicking in at least
    Quote Originally Posted by pete05
    yep i changed the yokes but didnt put a new crush tube in. needless to say there is a healthy knock on accel/deccel
    hello
  5. #140
    penrith nsw
    dont have any more spare yokes do you?
  6. #141
    NWA
    nope.
    why would you want one?
    hello
  7. #142
    penrith nsw
    i want to be able to bolt up a g series bolt pattern shaft to my f series diff. once i do that i can fit the whole jzx81 tail shaft instead of half mx73 and half jzx81 like i have now. my rear half is mx73 and its to small i feel
  8. #143
    NWA
    took it out the drags last night....
    13.3@106
    thats with the exhaust disconnected behind the cat and 16psi. it was pretty hot so everything in the engine bay was untouchable. there was also light rain on and off.
    the 2j is so torquey it starts spinning the rear tyres at about 1800rpm so its hard to stall it up.
    hello
  9. #144
    Turn off your brake locker and stop holding the front wheels still and you might get better traction
    Get a 5" monster tacho and dual shift lights and you will knock 3 seconds off that time!!
  10. #145
    hey nice job,
    i run the au thermos on full time; there is no switch and they have run fine for the past year.
    the only problem is that the temp goes us (factory temp guage) with air con on and driving up a big hill in hot weather.
    i have no underbody tray and they thermo fan shroud has big gaps around where it attaches to the radiator, but this would only cause a problem at low speeds as 'ram air' would be doing all the cooling above 30-40kph.
    i also had a custom power steering line made up, (200 bucks).
    also have noticed my dump pies have cracked at the flange, it looks kind of like yours, the pipes have to swist 90 degrees to make it past the steering.
    i suspect that there needs to be a supporting bracket to the engine as the 3 flange bolts are the only thing holding it on until it joins to the cat which it attached to that stock rubber exhaust mount under the car.
    once it if repaired i am going to heat wrap it to try and get some heat out of the engine bay, also installing a proper air box so my pod doesnt suck up the heat from the engine bay.
  11. #146
    13.3@106
    thats an impressive list of excuses
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
  12. #147
    NWA
    i know i know.
    if someone would have recorded my skid then it would have made up for it.
    the speedo read 180km/h for a couple seconds i think the Z12 cluster only reads to 180 so the wheels may have been going quicker.
    hello
  13. #148
    stunt dog Backyard Mechanic Esteban's Avatar
    wa
    What, no videos?? :-P
  14. #149
    NWA
    spur of the moment, i went out on my own.
    i got there late too so i only did 3 runs.
    i think it might have hit speed cut at 180 now
    hello
  15. #150
    NWA
    well, new gearbox is in. shifters much better. it manages to chirp second - yeh fully sick!
    spent 10mins polishing a couple things.... orbital sander on the cast alloy and the IC pipe + metal polish =....
    hello
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 05:27 PM
  2. 2JZ Water Pump onto 1JZ
  3. 1jz to 2jz
  4. 2JZ damaged, other options?
    By jzk25 in forum Tech and Conversions
    Last Post: 11-07-2006, 05:47 PM
  5. 1jz vs 2jz heads
