Page 7 of 7 FirstFirst ... 567
Results 91 to 98 of 98
Thread: Pod Filters-Do they work?
  1. #91
    Low Down Style Domestic Engineer Johnzoku's Avatar
    queensland
    Default Re: Pod Filters-Do they work?
    lolz... whatcyatalkingabout pod fliters provide massvie amounts of boost on Na cars yo! my boost guage says so! hahaa
    i guess your right, but then again running an uncovered oiled one *might* ignite... im sure if that that cop was speaking the truth, i'd belive it.
    i can imagaine someone not doing fuel lines up properly or having cracked fuel lines, people over oiling them, or relocating them into bad positions like over extractors etc... im sure they would ignite, but due to there own ignorance rather than just having one in a stock location.
  2. #92
    Quote Originally Posted by Starfire
    On a slightly more serious note, you _could_ install an intercooler on a naturally aspirated car and no, it won't do anything to improve performance, as at best it can only reduce the air temperature to slightly below ambient (if a water spray is used) which is pretty much what it starts off at anyway.
    the extra weight of the IC and water spray setup would also not be justified by the 0.005kW gain made.
  3. #93
    Mar 2008
    inner west syd now!
    ^^^ you could just redirect your windshield wipers and get the tube to spray fine mist into the inlet, if you really are desperate enough for extra power, whether or not it will increase power i cannot say for sure..
    unless your intake is basically sucking air from behind the radiator...but thats just stupid!
  4. #94
    N.S.W
    There's a good article at Autospeed explaining how to measure restriction in various part of the intake. The example car is a VL turbo, but the technique works on any car.
    Interesting to note that the air filter element (OEM paper element) was only causing about 3% of the total restriction in this case. I'd be very surprised if this wasn't the case for most paper elements.
    Good. Fast. Cheap.
    Pick 2.
  5. #95
    nick2b is on this new forum as Kyosho I heard.
    You obviously have poor hearing.
    I was on the old forum as Kyosho too...
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
  6. #96
    currently toyotaless Grease Monkey rn-85's Avatar
    Canturbury
    wraith has a water injection kit, in his shed. and one of our mates water injected his falcon with fairly cool results it's an old school mod but the falcon was injected to inprove ecconomy.
    Knowledge is knowing a tomato is a fruit.
    Wisdom is knowing a tomato has no place in a fruit salad.
  7. #97
    Its very common for engines with pods or trumpets with filters to catch on fire ei, sprintcars, carbies etc. The best thing you can do is keep the engine running and give it a rev. Providing it doesnt back fire again.
  8. #98
    Junior Member 1st year Apprentice turbo_gze's Avatar
    Quote Originally Posted by Kyosho
    Wasnt nick2b the guy that had that 929 with the plates sxc929 and it was ugly as hell? lol
    Pod filters are good for sound and sucking in hot air if not mounted in the correct place.
  1. Fuel filters and locations?
    By Cool1 in forum Tech and Conversions
    Last Post: 19-01-2006, 11:09 PM
  2. Replies: 1
