Page 5 of 7 FirstFirst ... 34567 LastLast
Results 61 to 75 of 98
Thread: Pod Filters-Do they work?
  1. #61
    Default Re: Pod Filters-Do they work?
    is that how you bore out your engines?
    Hehehehe.... well his garage isn't the 18R-G graveyard for no reason!
    seeyuzz
    river
  2. #62
    Its actually for porting and carbon cleaning reasons, the boring is a bonus
  3. #63
    id like to see air filter oil spontaneously ignite purely from underbonnent temperatures
    get the MSDS from the company (which they are obliged to provide by law) and it should have spontaneous ignition temp on it...
    however, when the oil is spread thinly over a porous surface, it is much easier to ignite.. the foam acting like a wick..
    as a comparison, try lighting a bucket of kero.. then dip a foam sponge in it and try...
    although it would probably take a naked flame to ignite a hot air filter under the bonnet, if it starts to burn, it will burn well.
    i've had petrol dripping onto exhaust and not ignite ... but i wouldn't recommend it
  4. #64
    Recommended practice for all WRX owners though. Might as well make the underside of the bonnet as black as the outside
  5. #65
    currently toyotaless Grease Monkey rn-85's Avatar
    Canturbury
    so if i made a tapered box opening at the top being fed by a bonnet vent. with the opening large enough to hold two paper filters. in side the box have a taperd bellmouth to the origonal airbox piping. this should be better than a pod, a unifilter or a stockairbox on all bases?. am i wasting my time doing that as well as making my car look stupid for no aparent gain, even with extrators. if not how about if my car had forced indution?
    stick with stock? or go with the above idea?
  6. #66
    Sounds like a waste of time as-is. If you had the forced induction, then you might be looking at some gains by means of reduced intake air charge temperatures. With forced induction, the air can be drawn from just about anywhere, one popular place is inside the guard, where bugs etc cant get in too easy, and heat is minimal. Also, bellmouths have proven to give negligible improvement in most cases of forced induction.
  7. #67
    Canturbury
    i heard from a guy i saw on the weekend that he notices no inprovment on his hyundai. it had a super cheap pod but thats not all, he wrapped half the pod in a sheet of aliminum foil to stop hot air. but you get that when you're a nissan man.
  8. #68
    Junior Member Carport Converter 4agte's Avatar
    FWIW the s2000 comes stock with as pod filter in an inclosed airbox
  9. #69
    yup would probably take a bit of petrol to start a fire ive dropped a decent ammount onto hot headers and it just evapourates
  10. #70
    Just a quickie guys, where in Sydney can I get a K&N panel filter setup for my stock AE82 twinkie?
    I imagine I'd have to run some ducting to get a decent cold air intake as well, any clues/tips greatly appreciated.
    Thankyou
    1988 Twinkie (one owner - purchased new)
  11. #71
    Certainly does ignite well, and burns well too:
    Thats after my supposedly inflammable Unifilters decided to light up after a decently hearty backfire......
    FWIW: i read a review a few years ago where they compared pod filters using a vacuum cleaner and a carbon filter paper and saw how much they trapped. Ill see if i can find it again.
    Edit: Founds it. This is the cut down review, ill see if i can find the full one:
    http://www.supras.co.uk/resources/Mk...airfilters.htm
    Edit2: Ahah, the full one. http://www.mkiv.com/techarticles/filters_test/2/
  12. #72
    Damn takai, that's no good
  13. #73
    Junior Member
    Jun 2008
    vic
    anyone tell me can u use an intercooler on a non turbo car for a cold air induction system
  14. #74
    no
  15. #75
    drunken escapades Conversion King fatboy13's Avatar
    Yeh bro fo shiz... go across to boostcruising for a full write up...
    sad....
    watching a bunch of supraforums members try to debate something technical is like watching a bunch of retards try to fuck a doorknob...
  1. Fuel filters and locations?
    By Cool1 in forum Tech and Conversions
    Last Post: 19-01-2006, 11:09 PM
  2. Replies: 1
