Results 16 to 30 of 45
Thread: Need help with SP1 wire into ECU (1JZ Cressida)
    Default Re: Need help with SP1 wire into ECU (1JZ Cressida)
    SP2 and SP1 are very different signals, I doubt they are even compatible with each other.
    The ECU will need both in order to not throw any codes.
    Montrose
    On mine, I was having trouble finding the speed wire, so I did the lazy thing and removed the instrument cluster, and just connected to the speed sensor wire behind there. I connected that to both SP1 and SP2 on my auto ECU, and it seems to work alright.
    Junior Member 1st year Apprentice gtfloor's Avatar
    W.A
    Thanks for that Jabtronic, if you could find the cressida 7m pinout diagram I'd appreciate it, yeah the only one I could find was for the supra, bloody yanks. Every diagram is either a U.S.A 1990 cressida or series 2 australian model with completely different wiring harnesses.
    Thanks
    Don't Trust Me I'm A Backyard Mechanic Jabtronic's Avatar
    Gold Coast, QLD
    The next time I'm out working on my car I'll grab the URL if it's listed on my printouts.
    I have a feeling I got them from http://www.1jz-gte.us/ which no longer works.
    Least it doesnt snore Backyard Mechanic Gary's Avatar
    hey fellas, just a quick one
    1JZ conversion MX83
    S1 loom, S2 cluster, where do i connect SP1 to on the cluster itself?
    JZX83
    UCF11
    sigh
    reprase... how on earth, does the S2 cluster (thats the elec speedo, not cable) get its speed signal from the gearbox?
    is it magic? im starting to think it is
    JZX83
    UCF11
    SP1 is the OUTPUT from the dash, not the input.
    The Z30 Soarer has 3 wires that go from the speed sensor, up the engine loom, across the body/dash loom and into the dash. They do not go to the ECU at all.
    I suspect the MX83 is the same, but the MX83 drawings I have dont have the speedo on it, so I'd say they are Series 1 drawings.
    i know
    as far as i can tell, speed sensor -> cluster -> SP1 to ECM
    SP1 is an output no doubt, but i have no cluster input at all. i cant for the life of me figure out where the input goes thanks for replying though
    JZX83
    UCF11
    Sensor on gearbox gets mechanical signal and makes it electronic to send to dash...trace wires
    Wilbo's JZA80
    Wilbo's JZZ12
    i cant trace wires
    im putting a S2 dash into an S1 cressida, that never had wires. it was just a speedo cable (mechanical)
    JZX83
    UCF11
    Quote Originally Posted by Gary
    i cant trace wires
    You can't find the pinout for the dash?
    Wilbo's JZA80
    Wilbo's JZZ12
    I hope this isn't too off topic but does any one have a pic of the back of an MX83 dash.
    thats it wilbo
    just a sec amichie ill get some up
    JZX83
    UCF11
    http://img.photobucket.com/albums/v4...hanalogue1.jpg
    http://img.photobucket.com/albums/v4...8dashelec1.jpg
    ive left a decent res so you can see it properly, if theres anything in particular you need a pic of, ive got both out atm
    JZX83
    UCF11
    I have some GX81 dash pinouts at home somewhere.
  1. ECU pinouts Gen 3 1GGZE (Definitive?)
    By infotechplus in forum Engine & Driveline Conversions
    Last Post: 24-09-2017, 10:29 PM
  2. 1jz or 2jz for cressida
    By FreeStyler in forum Tech and Conversions
    Last Post: 01-08-2013, 06:45 PM
  3. 1JZ ECU leaking capacitors.
    By Slim in forum Tech and Conversions
    Last Post: 03-03-2010, 08:29 PM
  4. 1JZ into MX83 Cressida Conversion
    By matt100kw in forum Tech and Conversions
    Last Post: 18-03-2007, 09:06 AM
  5. Cressida MX73 Conversions Guide Book
    By twentyEight in forum Engine & Driveline Conversions
    Last Post: 24-02-2007, 10:07 AM
