Results 1 to 5 of 5
Thread: JZA80 Wheel Bearings
    Returning video tapes 1st year Apprentice
    Jan 2007
    Default JZA80 Wheel Bearings
    Wheel bearings have now been an issue for me on both me JZA80's now, as now my car is making a horrendous noise from the rear wheel hubs.
    What I'm wondering, is rather than replacing them with new hubs and new OEM bearings, if there is an upgraded bearing I could get pressed into the OEM housing that would be better suited to hard driving conditions, as both my sets of bearings seem to have died around the 100k km worth of travel and I would like something that would not need replacing with hard driving after 50, 70 or 100k kms.
    Are there any local products I could use for this task??
    Jun 2007
    Default Re: JZA80 Wheel Bearings
    The bearings usually wear out the sleeve which they are surrounded in, so you shouldn't need new hubs unless the new bearings aren't a reasonable tight fit in the Hubs.
    Jan 2007
    Quote Originally Posted by abently
    When I ordered my last set of bearings, I was told that it was recommended to replace the hubs aswell - they didn't give me a reason for this, but I do know that when my mechanic pulled the hub out of my old car, the bearings fell straight into his hand...
    Perth, WA
    could it be the sleeve that is fall on his hand? if the sleeve then you probadly have to change the hub, if it is bearing then you just need to replace the sleeve+bearing
    wa
    also make sure your tyres arent worn unevenly on the edges(run you hand around them)and see if they are flatspotted
    they can make a bearing type noise that can catch a lot of people out
  1. Basic Steering Wheel Conversion
    By Andrew162 in forum Tech and Conversions
    Last Post: 23-11-2006, 09:43 PM
  2. MA70 Wheel Bearings
    By Flebbert in forum Tech and Conversions
    Last Post: 11-10-2006, 08:47 PM
  3. help please do i need new wheel bearings?
    By hunty in forum Tech and Conversions
    Last Post: 19-06-2006, 02:24 PM
  4. ae86 te71 disc brake rear wheel bearings
    By SRacin in forum Tech and Conversions
    Last Post: 31-01-2006, 05:43 AM
  5. Replies: 4
    Last Post: 08-09-2005, 12:17 PM
