Results 46 to 60 of 63
Thread: running no BOV
  1. #46
    Default Re: running no BOV
    You could just remove the vaccum hose from the bov and block it.
  2. #47
    do i need to give u a captain obvious picture too
    i know that there is no such thing as wastegate flutter, i also know how much norbie hates noobs, and how much he love to E-thug them when the stuff up
    The boobs are back
  3. #48
    Depending on the design though some run a very soft spring (i.e. those designed with a larger surface area on the the vacuum side of the piston) which is easily overcome by moderate boost levels. The kind of people that need to prove this to themsleve are pretty thick anyway so it needs to be without doubt not opening
    My KE25 thread
  4. #49
    block what sorry, if it is in fact leaking, wont the piston still go up with the pressure
    The boobs are back
  5. #50
    sorry i meant block the vaccum but wasnt refering to your problem more so how to hear the hektic flutter.
  6. #51
    Forum Sponsor Conversion King
    nope then it will leak like a bastard.
    you have to remove said bov and block the pipe (unless thats what you meant)
    linden
  7. #52
    if i just get the piston tacked to the body would that be enough, or will it still leak around the piston, or would the leakage be negligible
    The boobs are back
  8. #53
    If it's just like most aftermarket BOV open it, remove spring, add spacers, refit piston with silastic.
    That won't leak.
    Any half decent BOV will usually have an aluminium body and brass piston anyway so welding that would be no go.
    There are about a thousand (well not quite) simpler ways to work out if your bov is "leaking" than welding the thing. Surely you could think of a few.
    My KE25 thread
  9. #54
    Quote Originally Posted by Mr DOHC
    you could do that or just remove it all together and block it off.
    with the auto you dont need a BOV but there still nice to have.
  10. #55
    Best solution mentioned and the simplest.
    My KE25 thread
  11. #56
    On the 3s it would drop off boost for about 2.5secs between the 2nd-3rd shift (w58 + 4.11 diff) and it was a prick to drive hard as it came on so aggressively that it would then cook the tyres (great while drifting, shit while racing) but after the BOV went on it wouldnt drop off as much and was easier to drive the car hard.
    Yikes, 2.5 secs!!! what was the turbo a T78? The GT8 is off boost only as long as your off the throttle Zero lag on gear change.
    Totally agree with the Trust call. I run a Type R on the GT8 to try and shut the twin surge symphony the TTUZ otherwise plays...just a tad too attention catching
    The main reason it dropped off so much was when it came on in 2nd it would light the tyres then when you went for 3rd it wouldn't have the roadspeed and dropped the revs down too much but when the bov was fitted it stopped the turbo from stalling therefore lowering the response time to get it going again.
    It's nice to have 4 litres of na power to get you going again thats why i just bought an audi 4.2L 40v V8
  13. #58
    Nice. Big fan of the Audi, they are such sleepers....the old(ish) RS4 with the TT V6 is a fave.
    WRONG
    its the wastegate
    My friend's VL flutters and I can assure you it's not the wastegate, it has a screamer pipe so you KNOW when it's open!
    Anyway dose is where it's at bro.
  15. #60
    You can get wastegate chatter but sounds very different to compressor surge and have only ever heard this on race cars. None of my turbo cars have ever done it that's for sure
    I've never had a think about what would cause it but if compressor surge causes the boost signal to go a bit mad then that might cause the WG to fluctuate rapidly as well, producing the 'chatter'?
  1. Should I add a BOV to my 1ggte?
    Last Post: 10-04-2008, 08:39 PM
  2. running in oil - reccomendations?
    By AndyTTR in forum Tech and Conversions
    Last Post: 01-11-2006, 12:15 PM
  3. tial BOV not operating correctly
    Last Post: 06-09-2006, 05:50 PM
  4. BOV question (noob alert)
    By Diz44zy in forum Tech and Conversions
    Last Post: 31-08-2006, 05:25 PM
