Results 16 to 30 of 63
Thread: running no BOV
    User Conversion King
    NWA
    Default Re: running no BOV
    Quote Originally Posted by Jesse
    No blow off on the 1g's.... I swear mine has some form of plumb back valve.
    I know lots of people say they dont, but jumping off the throttle i can hear some form of boost pressure release.... someone clarify? Havent really played with the motor much. Suppose if i did i could work out what was going on....
    time to investigate....
    problem being only getting positive pressure under load, which means driving it.... hmmmm
    when you jump off the throttle, there is 10psi in one part of the pipe, atmo pressure in the other side of the pipe and no restriction between; the air will just flow to the lower pressure region.
    all the air just comes back through the turbo housings and out the air filter
    hello
    i never realised 1G's didnt have BOV's
    case closed
    The boobs are back
    by doing this you leave yourself open for shaming by having a dentist's car that makes fuly hektik dose sounds
    Canada
    My ST165 didn't have a BOV either.
    The turbo was good for 190k...
    Jun 2007
    If the Turbo isn't running on the far-right-edge of the Compressor map, then just get a small 20-25mm BOV to allow just enough Air to escape, too much Air escaping also kills your response as bad as Surge does....
    Forum Sponsor Conversion King
    Quote Originally Posted by abently
    not sure about that one.
    it would all depend on where its mounted.
    i run greddy type R BOV on all my personal cars and generally set them soft, this compared to no bov made a massive difference in recovery time whilst changing gears.
    as far as im conserned with BOVs the bigger the better (and the bigger they are the less it sounds like youve just thrown a bucket of water at someone) and i HATE the woooooooooosh sound small BOVs make.
    but i know stitt loves it
    linden
    Were talking about BOVs here right?
    ummmm yes.
    i seem to remember him testing it for about 15mins after it was fitted (and pretty much every time he drove it from then till now).
    Haha, that's right. Up and down your driveway to make sure it was set soft enough for a big farkenwhoooosh11!!! when it was revved
    and after the driveway tests it was the round the block umpteen times just for good measure.
    and then on to George St
    Jun 2006
    a mate of mine had issues with his valve leaking, so he packed it full of 20 cent pieces so it just gates now. has a lot less idle issues these days (also handy if your short on change)
    Unless you are running a ridiculous amount of boost, then you will have no problems running no BOV.
    The reason a BOV is run in the first place is when the throttle body slams closed (when stepping off) there is a large amount of backpressure. Of course this has nowhere else to go but back past the compressor wheel of the turdbro and out through the air filter, until you go back on the throttle.
    This takes place in milliseconds.
    But. unless you are running 9872367243 PsI, then you should have no probs.
    Phil: there should be no issues with you not running a BOV. However, as I understand it under sport compact rules you must have a large sticker on the side of car that reads
    FULLY SIC DOSE ULEH!
    Otherwise, no points earnt at jamboree will be accumulated
    QUICKEST 1JZ'S IN OZ
    linden
    Interesting Linden as the back to back testing (Haltec data log) i did on my old turbo 18RG running a big TO4B front cover, showed no BOV provided better response with no BOV. Was bugger all in it though and the BOV whoosh was quieter than the surge so still ran the BOV.
    Seems to be very much effected by the type of BOV and the setup of the car as to how much effect on response it has?
  1. Should I add a BOV to my 1ggte?
    Last Post: 10-04-2008, 08:39 PM
  2. running in oil - reccomendations?
    By AndyTTR in forum Tech and Conversions
    Last Post: 01-11-2006, 12:15 PM
  3. tial BOV not operating correctly
    Last Post: 06-09-2006, 05:50 PM
  4. BOV question (noob alert)
    By Diz44zy in forum Tech and Conversions
    Last Post: 31-08-2006, 05:25 PM
