Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Thread: harness at club events
    Default Re: harness at club events
    psychofox: If you dont mind could you dig out the supporting cams document?
    The cams manual states that a road registered car does not have to comply with schedule I which covers harnesses. Those compliance things you listed are from schedule I so it does not apply to road cars.
    Im not saying your wrong im just saying that the cams manual does not support what your saying.
    What does apply to road cars? it seems to be a big grey area.
    Oh btw is this fletcher? i met you at the last huntley.
    good find YLD-16L
    Gravel Lover Backyard Mechanic stumpygt4's Avatar
    A road car is no longer a road car once it enters any form of competitive motorsport, it becomes a copetition vehicle. And harnesses for a road car do not meet the ADR's
    As far as I am aware
    Jeff Thomas
    TOYOTA TEAM CELICA
    1 x 1989 ST165 rally car, 1 x 1988 ST165 GT4 spare car & 1 ST185 khana cross car. (for now )
    1 x GT86
    No a road car is still a road car.
    An unregistered road car is subject to full race regs but a road registered car is not
    Junior Member Domestic Engineer psychofox's Avatar
    yep is is Fletcher.
    Sub Section 18 of Schedule B of the CAMS Manual states:
    18. Notwithstanding the above requirements automobiles registered for unrestricted road use shall not, when competing
    in Drifting, Single- and/or Multi-car speed events (other than racing), be required to comply with the provisions of
    sub-sections 2, 5, 8, 9 and 11 of this Schedule.
    So this means Road Registered cars are exempt from the following items:
    2. if fitted with any crankcase breather discharging to the atmosphere, each breather be vented into a catch tank of
    minimum capacity of two litres for engines up to 2000cc or three litres for over 2000cc. Regulations for competitions
    on unsealed surfaces may waive this requirement;
    5. be so constructed that any longitudinal propeller shaft shall be protected from striking the ground;
    8. comply with any Supplementary Regulations which require the fitment of a device to prevent the loosening of any oil
    drain plug;
    9. if fitted with a scatter shield, be compliant with Schedule M (refer to Section 6 of the CAMS Manual of Motor
    Sport);
    11. be fitted with a dual circuit braking system save for automobiles manufactured prior to 31 December, 1973 or of the
    5th Category.
    There is no exemption for any of Schedule A, which contains this item:
    11. be fitted with safety harness or seat belts compliant with Schedule I (refer to Section 6 of the CAMS Manual of
    Motor Sport);
    So ALL Cars competeing in ANY CAMS event must comply with Schedule I.
    Wollongong Sporting Car Club - Secretary
    Current Cars:
    2004 TW Magna VR-X AWD w/6G74 - Tow Car
    1989 AW11 MR2 w/4A-GE 20V - Track Car
    thanks for your reply
    There seems to be two versions of the same thing on their website.
    http://www.camsmanual.com.au/speed.asp
    Ive been going off that which states:
    Notwithstanding the requirements set out in Schedules A and B, automobiles registered for road use shall not, when competing in Single- and/or Multi-car speed events (not racing), be required to comply with the provisions of sub-sections 2, 3, 5, 8, 9 and 11 of Schedule B.
    But i would assume the passage that is actually in a schedule would be more accurate then the one that is not.
    Hmmmm just seems odd.
    mmm that is odd. I'll chase that up with CAMS. Its a bit of a loophole.
    You were in the JZA61 right?
    Current Cars:
    Yes indeedy the ugly looking white one. Any tips for making a better time ? I cant have rona beating me with a ed powered 7m.
    I might bring it along next time anyways, is there an actual cams official there on the day? I might just have a chat to him.
    Ive tried to contact cams but they dont reply
    thanks for the info man.
  8. #38
    Quote Originally Posted by naten
    Naten, I contacted them with my question about the seats expiry via email and had a friendly reply in about 45 minutes from the Technical Liaison Officer.
    My KE25 thread
  9. #39
    they finally replied just took them a while.
    So there we have it, the harness could be used if it had some form of austrailian compliance but it doesnt so i cant
    oh well
    thanks to all that replied and i hope this info can help someone else.
    Hi Nathan,
    What the regulations mean is that if an automobile is road registered it
    does not have to have a harness but if it does have one fitted then the
    harness must comply with the provisions of Schedule I.
    So you could fit one to your car for competition in a Club Speed Event
    (note that it may not be legal for use on the road though - check your
    state authority such as Vicroads / RTA) but it must be as per Schedule
    I, so if you chose to use an FIA or SFI standard harness it must be
    within date.
    The belt you have will presumably then have either an ECE approval (R16
    usually marked as E1 or E3 or similar) or AS approval (AS 2596).
    Provided it is correctly mounted and in good condition you could then
    use it.
  1. Toyota Car Club events for rest of year now updated
    Last Post: 31-05-2007, 02:44 PM
  2. NSW Supra Club : Christmas Party : Sunday 3/12/06 - Pics & Vid Up
    By Alchemist in forum Previous NSW Events
    Last Post: 04-12-2006, 09:55 PM
  3. Toyota Car Club Qld events for Aug/Sept
    Last Post: 11-08-2006, 12:53 AM
  4. Qld Supra Club cruise - Aug 6th
    By Mr Ed in forum Queensland Events
    Last Post: 01-08-2006, 11:23 PM
  5. Toyota Car Club events for Feb to August 2006
    Last Post: 01-02-2006, 03:57 AM
