Results 1 to 10 of 10
Thread: MA61 5-ME at 2000rpm Cuts off then revs again until 2000 ???
    Default MA61 5-ME at 2000rpm Cuts off then revs again until 2000 ???
    Well i have no idea how this happens so i am hoping somebody can help PLEASE.... the engine starts fine and will idle forever smoothly .
    When i hold the revs at 1800 she still going smooth but when i hold on 2000rpm (when the tach light for 2k lights) it suddenly cuts off, drops to about 1300 then will rev back up to 2000 then same again etc...
    if i hold revs at about 2400 it'll stay there forever too !
    This gives me a massive flat spot on acceleration so i obviously need to find the fault
    Please Help Anyone please
    Thanks in advance for any response that helps
    P.S. i already thought about bypassing the 2k light on the tacho hehehehe
    Default Re: MA61 5-ME at 2000rpm Cuts off then revs again until 2000 ???
    tps in wrong spot
    it's a switch to enable decel fuel cut - it's turning on when throttle is open instead of when its shut - that switch makes the ECU cut fuel until revs are just above idle (e.g. 1300rpm).
    Victoria, Mt Macedon
    If the chuckster's suggestions doesn't work, try clearing the ECU error cods (unplug power to ECU for 30 secs). I had exactly this problem on a 4Y-E over the weekend and solved it by doing that.
    Hen
    5ME doesn't store ECU codes - it's too low-tech for that level of capability.
    LOL @ error codes on a 5M-E ECU. The thing is less sophisticated than a $5 digital watch!
    Chuckster is correct, the TPS is misaligned. A multimeter and a bit of patience will sort it out.
    Lower tech than a 4Y-E? That's amazing. Maybe my problem was in fact misaligned TPS and the ECU "fix" was just a placebo.
    primary diagnostic tool for 5ME ECU = hammer.
    Chuckster you Legend !! if only you had a spare engine to donate to improve my ongoing predicament. I agree totally but i gotta keep this peice o crap for now
    we can dream tho hey
    i'll post the result as soon as i get the job done
    thanks for the response
    Chuckster = Bigger LEGEND !!! adjustment of the TPS by about 3mm worked a treat .
    Only thing i can see now is the trail of black smoke when i decelerate.
    Acceleration is very keen
    (Imagining a better donated chuckster engine)
    a BIG Thanks to you
    odd that you should say spare engine - i have an unused 5ME in a supra out the front of my house - when i remove it to get the W58 off it, i'll have a 5ME to dispose of... for a reasonable fee
  1. MA61 Part Numbers & General Infomation
    Last Post: 27-03-2013, 12:31 AM
  2. ma61 front end upgrade writeup.
    By nb86 in forum Tech and Conversions
    Last Post: 22-07-2009, 10:24 PM
  3. MA61 – GH Sigma LCA Upgrade - Negative Camber + Extra Track - GUIDE
    Last Post: 06-12-2006, 11:56 PM
