Results 16 to 30 of 59
Thread: Slotted discs for AE101 superstruts?
    Chiba
    Default Re: Slotted discs for AE101 superstruts?
    Correct. Which makes the AE92 conversion possible.
    Quote Originally Posted by JP
    get a slotted DBA743, machine the outside diameter down from 278 to 275mm and redrill from 5x100 to 4x100.
    How about the DBA759... It's already 275mm x 25mm and is 4 x 100 with a 55mm centre hole...
    ([][][]II--LT--II[][][])
    That dude with the AE95's Backyard Mechanic Kebin's Avatar
    Constitution Hill, NSW
    Quote Originally Posted by TERRA Operative
    Cutting the slots won't cause problems with cracking will it?
    Should be fine so long as they are all accurately slotted.
    I gave the machinist an existing pair of "off the shelf" slotted rotors from another vehicle and asked him to copy the grooves.
    he needs a disc with a 54mm center hole
    If you continue to have difficulties with chasing the rotors maybe better to upgrade existing parts. Have you considered just getting better pads etc?
    Chiba
    Quote Originally Posted by twentyEight
    Centre hole's gotta be 54mm....
    Quote Originally Posted by Kebin
    My SS rotors are getting down to min thickness, So I need new ones anyway.
    well my Rotors on my AE101 Rolla are from RDA and cost around $200 for the pair.
    What is autosalon? Sounds kinda homo.
    Quote Originally Posted by tooch
    It's extremely homo. Basically a whole lot of sh1t cars, with ugly wheels, and a lot of 16-20 year old rockstars with trendy mullets and gay shirts.
    Slayer Of Toymods Wookie Slayers
    Chiba
    superstrut? what's the model no?
    i think some people need to read this thread.
    http://www.toymods.net/forums/showthread.php?t=142
    Chiba
    Yea, but I got the superstruts on the 101 Levin, I'm not doing the upgrade. I just want slotted disks without paying the Toyota tax.
    your easiest source of slotted discs to suit your AE101 GTZ with 275mm discs, is to buy the ST185 DBA slotted discs, take them to Craig at Extreme Custom Engineering on Meadow Avenue at Coopers Plains and get him to reduce the diameter by 3mm and redrill them to 4x100.
    I realise this, but if you read the thread it kinda indicates that you cant buy the original discs here in australia - you have to buy the DBA743 discs and have them redrilled and machined to suit.
    Hence why i pointed you in the direction of that thread.
    You should've listened to JP
    I got discs from an ae111 blacktop 20v front cut. They were leftovers which i found in the parts for sale section here.
    I simply had them machined then eventually got slots machined on them. Though i still havent fitted them to my wagon as of yet I think i got them for around $30 or so. All up with having them machined and slotted would be around the $80-$90 mark for the pair.
    I measured them up and taking in to account i had them machined etc. i got:
    Diameter: 258mm
    Height: 47mm
    Thickness: 22mm
    Would these ones be suitable for what TERRA Operative is after?
    Because if they are, then the AE93 disc DBA 708 are 258mm x 22mm have a height of 48mm and a 54mm centre hole and comes in the Slotted version...
    no - the superstrut brakes are much larger and thicker.
    By The Witzl in forum FAQ
  2. MS123 discs onto MA61?
    By Gibbon in forum Tech and Conversions
    Last Post: 20-10-2006, 10:51 AM
  3. Slotted vs. Standard for road use
    By Shifty in forum Tech and Conversions
    Last Post: 21-03-2006, 11:32 AM
