Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
Thread: carbied 1g
    Default Re: carbied 1g
    does that include gas carbies 6boost?
    mine made 150 hp at the wheels with only about 20 k's on the motor, running a gas carb and standard everything else.
    i thought we had heard the last of that 11 second pass...
    Lick my hairy Backyard Mechanic Turdinator's Avatar
    You wouldn't put 3 sidedraft carbies on any motor expecting to get the best 1/4 time possible. Turbos and EFI are for that. I don't think you guys get it.
    theres alot of time to be spent tuning aftermarket ecu's. especially on a 1g, with no off the shelf products.
    often a ecu will idle very nicely, and will make big smooth power on WOT, but the in between can leave alot to be desired. this problem can be eliminated to a certain extent with carbies, but money spent in either field is gonna be money you could have spent doing something else.
    BS Microleb and a day to make a loom and wire . Plug and play of course not, but theres not alot of PNP ecus for toyota's full stop.
    After cold start you wouldn't know my car runs an aftermarket ecu, its smoother then the stock ecu as theres no flat spot.
    If in doubt power out
    Quote Originally Posted by 7MA61
    was it real time tuned?
    Tuned on a dyno cost $350 bucks, probably spent 2 hours on the dyno and its still a fairly average tune ie rich. But its perfectly smooth to drive.
    lol, get it to idle, now tune it to WOT. the in between doesnt matter anyway
    Wrong hell in my vid of it you can see it being tuned at part throttle at various rpm loads
    http://supravideos.935motorsports.co...7mge%20mk2.wmv
