Results 1 to 15 of 19
Thread: MA61 Rear end into a RA65ST?
    Toymods Club Member 1st year Apprentice
    Default MA61 Rear end into a RA65ST?
    Ok does anyone know if a MA61 rear end will bolt into an RA65ST(sedan not hatch)?
    Default Re: MA61 Rear end into a RA65ST?
    deleted cause i might have been wrong
    Junior Member Grease Monkey Intense's Avatar
    ra65 is IRS
    Both cars have F series diff and from what I've read It's a farily simple swap. The entire IRS subframe bolts in, you get disks on the rear and the F series LSD
    Sa22c Series 1 rx7, 12a extend port, 900rwkw @ 93,320 rpm sold
    Ra65 celica hatch, 22re with 2.25" exhaust, 500Nm @ 27rpm sold
    Ae86, 4agze, 170Takumi Powers @ 11,000 rpm
    Yah, bolts in.
    RA65 is IRS regardless of hatch or sedan
    Also when you change to disk I suggest that you use the MA61, or the correct bias valve for the brakes!
    In case you're not aware, the only difference between the two is the disk brakes and LSD centre in the MA61.
    Junior Member Backyard Mechanic haison's Avatar
    Well i just found out my MA61 has a celica subframe in it. It went in with a few minor modifications so it's not a straight forward swap but not too hard afaik.
    1984 MA61 - http://www.toymods.net/forums/showthread.php?t=12340
    1972 RT81 - http://www.toymods.net/forums/showthread.php?t=24160
    RObErT_RaTh - I think it's fair to say we all love the bush
    Viper_Nipplex - If bush is this popular, just wait until the boxes are ready
    What are those minor modifications you talk of?
    I know the swing arm mount points on MA61's are 65/70mm where as Celica's are 70/70mm.
    Thats the only difference I know of.
    That must be it. It was done before i owned the car so don't know specifics and mechanic doesn't really remember.
    Every celica I have seen has had 65/70....
    Shorter hand brake cables maybe between coupe/hatch?
    I know xZ1x's cables are ~25mm longer, as is the rear half of the driveshaft.
    Track is also 40mm wider, but not on the Celica
    Junior Member Domestic Engineer ill-minded's Avatar
    May 2006
    i'd say probably not, the wheelbases are the same across the coupes and hatches
    May 2006
    oh and i can also confirm that a 1985 RA65 ST has the 65/70 mounting points (just checked then)
    By The Witzl in forum FAQ
  2. MA61 – GH Sigma LCA Upgrade - Negative Camber + Extra Track - GUIDE
    Last Post: 06-12-2006, 11:56 PM
  3. Guide: DIY MA61 Rear Spring Replacement
    By RObErT_RaTh in forum Tech and Conversions
    Last Post: 25-07-2006, 06:15 PM
  4. MA61 Noltec and SuperPro Bushes: PN#'s and $$$
    Last Post: 19-01-2006, 07:00 PM
  5. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
