Results 16 to 19 of 19
Thread: MA61 Rear end into a RA65ST?
    Toymods Club Member 1st year Apprentice
    Default Re: MA61 Rear end into a RA65ST?
    Ok so thats all abit confusing, what conclution have we come to, are the mesurments the same or not? does anyone know for sure?
    The hand brake cable doesnt matter if it's the same subframe, il just attach the one that is currently in the car to the new subframe if there different.
    TY for the tip on the brake bias valve, allready got that one covered.
    Junior Member Domestic Engineer ill-minded's Avatar
    May 2006
    the general consensus seems to be that the everything should swap straight over without any hassles (unless your particular celica has the 70/70mm mounting points. you would be best to check this yourself beforehand though to make sure) except that you may need to check your brake bias and if its wrong, change the brake bias valve to the ma61 item.
    other than that, handbrake cables should match up and everything else should be fine.
    someone may wish to correct me if i've missed something out.
    RA65 coupe represent!
    it's be tried and tested many times in the US, i'm sure a complete subframe swap would provide to be somewhat hassle free.
    Montrose
    Can't say I had any trouble sticking 61 arms in my 65...
    By The Witzl in forum FAQ
  2. MA61 – GH Sigma LCA Upgrade - Negative Camber + Extra Track - GUIDE
    Last Post: 07-12-2006, 12:56 AM
  3. Guide: DIY MA61 Rear Spring Replacement
    By RObErT_RaTh in forum Tech and Conversions
    Last Post: 25-07-2006, 07:15 PM
  4. MA61 Noltec and SuperPro Bushes: PN#'s and $$$
    Last Post: 19-01-2006, 08:00 PM
  5. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
