Results 16 to 24 of 24
Thread: 1JZ problems, wont rev, Please help ASAP!
    Default Re: 1JZ problems, wont rev, Please help ASAP!
    Thanx guys, as usual toymods = more help then toyota! lol
    Malicious
    BTW that part number is for some thing off a camry? is that right? the guy at oakleigh toyot was really helpful but couldn't find the part seperate from the loom.
    But I ordered one of that part number in hoping that its right and that its just a shared part. It's only $10 so its no biggy if its wrong.
    Just an FYI for y'all!
    Malicious
    Like to join in with a request for the Toyota number for 1JZ individual coil packs. Can anyone help .... please.
    Junior Member Grease Monkey EvilJack's Avatar
    State
    ***** Part Number Application Models ***** Date =08/07/07 Page =001
    Part Number (pnc#) Part Name Catalog Models Prod.date Models(description)
    90919-02205- (19500 ) Coil Assy, Ignition 291130 Supra 9305-9709 2jzgte..jza80
    90919-02205- (19500 ) Coil Assy, Ignition 291120 Supra 9008-9305 1jzgte..jza70
    90919-02205- (19500 ) Coil Assy, Ignition 321140 Soarer 9105-9608 1jzgte..jzz30
    90919-02205- (19500 ) Coil Assy, Ignition 332180 Aristo 9110-9708 2jzgte..jzs147
    90919-02205- (19500 ) Coil Assy, Ignition 311160 Mark 2 9008-9210 1jzgte..jzx81
    90919-02205- (19500 ) Coil Assy, Ignition 311170 Mark 2 9210-9609 1jzgte..jzx90
    90919-02205- (19500 ) Coil Assy, Ignition 312160 Chaser 9008-9210 1jzgte..jzx81
    90919-02205- (19500 ) Coil Assy, Ignition 312170 Chaser 9210-9609 1jzgte..jzx90
    90919-02205- (19500 ) Coil Assy, Ignition 313160 Cresta 9008-9210 1jzgte..jzx81
    90919-02205- (19500 ) Coil Assy, Ignition 313170 Cresta 9210-9609 1jzgte..jzx90
    90919-02216- (19500 ) Coil Assy, Ignition 311190 Mark 2 0010- 1jzgte,1jzge..jzx11#
    90919-02216- (19500 ) Coil Assy, Ignition 291130 Supra 9709- 2jzgte..jza80
    90919-02216- (19500 ) Coil Assy, Ignition 322110 Progres 9805-0104 1jzge,2jzge..jcg1#
    90919-02216- (19500 ) Coil Assy, Ignition 3311a0 Crown/crown Majesta 9909- 1jz#,2jzge..jzs171,173,179
    90919-02216- (19500 ) Coil Assy, Ignition 332190 Aristo 9708- 2jz#..jzs16#
    90919-02216- (19500 ) Coil Assy, Ignition 311180 Mark 2 9609-0010 1jz#,2jzge..jzx10#
    90919-02216- (19500 ) Coil Assy, Ignition 312180 Chaser 9609- 1jz#,2jzge..jzx10#
    90919-02216- (19500 ) Coil Assy, Ignition 313180 Cresta 9609- 1jz#,2jzge..jzx10#
    90919-02216- (19500 ) Coil Assy, Ignition 321140 Soarer 9608-9709 1jzgte..jzz30
    90919-02216- (19500 ) Coil Assy, Ignition 321140 Soarer 9709- 1jzgte,2jzge..jzz3#
    90919-02216- (19500 ) Coil Assy, Ignition 323110 Origin 0008- 2jzge..jcg17
    90919-02216- (19500 ) Coil Assy, Ignition 331170 Crown 9609-9904 1jzge..jzs130
    90919-02216- (19500 ) Coil Assy, Ignition 331190 Crown/crown Majesta 9508-9609 2jzge..jzs155
    90919-02216- (19500 ) Coil Assy, Ignition 331190 Crown/crown Majesta 9609-9909 1jzge,2jzge..jzs15#
    90919-02216- (19500 ) Coil Assy, Ignition 331190 Crown/crown Majesta 9909- 1jzge,2jzge..jzs151,153,155..sed
    -Street Drag Machine- Grease Monkey renxun's Avatar
    Jan 2007
    Sabah
    theres 2 possibilities... 1st the jza stock ecu are crap and are well known to either under deliver fuel or over deliver fuel when its faulty....2nd ..check your crank sensor wire connection. if u stand in front of your bonnet its behind your water pump... notice the red colour connector that it use to tap both wires.... under heat it can hardened up,crack and left your wire connection unreliable.... last time i had similar prob with you ... changed fuel regulator,wash injector,ecu,wiring,fuel pump only to find out its actually a connection error. check the small things b4 venturing into bigger one
    Drift Drift Drift and drift untill getting high fever...
    You are a legend EvilJack, thanks a lot for the info.
    Just an FYI the part number was correct, even tho the computer came up with it being a camry part. The only real difference is that it doesn't have the red Oring (which I'm assuming is to keep the water out) that the original does. It is also more robust as Endless has said!
    Cheers again guys!
    Malicious
    Roll Ons? Carport Converter Endless's Avatar
    Have you clipped one on and seen how tightly they connect?
    I doubt any water would be getting through there!
    Yeah I have, certainly not worried about water getting in! Tight as a nuns, that clip makes it a challange to actualy get off now compared to the loosy goosy shit that the old ones were!
    Just pointing out the differences.
    Malicious
  1. 1JZ problems
    By cressida_1jz in forum Tech and Conversions
    Last Post: 01-09-2007, 01:57 AM
  2. 1JZ MX83 wiring problems - MAP sensor?
    By Jabtronic in forum Tech and Conversions
    Last Post: 10-07-2007, 07:42 AM
  3. 1jz problems
    By JapTastic in forum Tech and Conversions
    Last Post: 29-06-2007, 09:45 AM
  4. MA61 + 1JZ + Heater problems
    By Gibbon in forum Tech and Conversions
    Last Post: 11-05-2007, 02:25 AM
  5. 1jz problems with idle and snapped off screw head.
    By tyottsoarer in forum Tech and Conversions
    Last Post: 22-05-2006, 11:39 AM
