Results 1 to 6 of 6
Thread: about changing the plenum
    -Street Drag Machine- Grease Monkey renxun's Avatar
    Jan 2007
    Sabah
    Default about changing the plenum
    im running a 1jz big single and i was wondering what are the advantage could i gain if i were to change to bigger size plenum? and is there a must to install the over size throtle if i use the oversized plenum? what are the gain could i expect to get from there..?
    Drift Drift Drift and drift untill getting high fever...
    CAE86 Grease Monkey ae95's Avatar
    Default Re: about changing the plenum
    depends on how much hp your are making
    Jan 2007
    Sabah
    currently just slightly above 400whp
    Junior Member Grease Monkey Adrian's Avatar
    Apr 2007
    W.A
    A bigger Plenum means you will loose some bottom end. But a bigger throttle body will help.
    However you will increase your VE (Volumetric Efficiency) meaning you will get some more HP, providing its not to big of course.
    On the old site, there was a really good tech doc about how much air a given engine would consume at what boost level. Then work out the area of the current TB to determine if it is a restriction or not.
    As I said, BIG power has been made on stock plenum and TB. There is probably some gains to be had still though.
    QUICKEST 1JZ'S IN OZ
    Penrith BC
    search, this thread has been done to death
    ../delete/ban
    tech moderator
  1. [Melb] Bigport 4A-GE Plenum cut+shut
    By Nim in forum Tech and Conversions
    Last Post: 14-06-2006, 08:54 PM
  2. Stainless piping diameter question eg plenum
    By Mr Multivalve in forum Tech and Conversions
    Last Post: 27-04-2006, 09:31 PM
