Results 1 to 3 of 3
Thread: 2tg, oil spitting out of breather line.
    Default 2tg, oil spitting out of breather line.
    Hey guys,
    Hoping someone else has had this problem,
    I have a 2tg that seems to spit oil through the breather line on top of the engine. It does have a PCV valve comming off the head, but it had a whole heap of oil inside of it. Only happens when revving past 5,000rpm.
    Has anyone else experienced this?
    Thanks
    Blake
    Default Re: 2tg, oil spitting out of breather line.
    yes, i have the same problem, That pipe should plug back in to the airbox if you have one, or if you have the lynx sponge type ramflow filters, connect that pipe onto the rear carby via the back plate with a hole especially made for this purpose, if it doesn't reach the front one. Get an oil catch can, or just block it for an easy fix.
    deepdishfactory
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    most probly rings, check your compression ratio,
    as fonnzy said, get a catch can or make one up yourself with a gatorade bottle with holes drilled into the lid and a hose going into it and connect it to the rocket cover,
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
  1. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 07:29 PM
  2. Replies: 12
    Last Post: 16-12-2005, 08:03 AM
