Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
Thread: 1jz fuel cut defender
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    Default Re: 1jz fuel cut defender
    i just bought one from ebay in the states, got it for $130 delivered.
    Junior Member Grease Monkey ripfast's Avatar
    is the DIY fuel cut where you use a diode?
    1985 VK Commodore with 1JZ-GTE
    1989 GZ20 GT-T Soarer with 1G-GTE
    2008 IS250 with not enough power
    Quote Originally Posted by Officer Doofy
    1j map sensor reads to 15psi 5v
    No it doesn't it reads to 1.16 kg/cm2 (16.5 PSI) @ 4.912 mV
    JZA70|R / 12.45 @ 111 mph.
    W.A.
    Quote Originally Posted by JZA70 R
    Awesome info, i was about to bust up a post to see if anyone knew the exact figure
    kinda safe to say that a 1jz mines ecu is probably tuned to the full reading of 16.5 psi then....after that its gunna start leaning out i spose.
    I was running my FCD at 4.2Volts @ 15psi it made 225rwkw with stock dumps and a shitty cat. It ran a best of 12.47 @ 109.8mph on Et streets @ 17.8psi. After installing DUmps + a new Catco Metal cat and new coil packs, I have managed 12.18 @ 113mph witht he FCD at same voltage( bumping off the limiter also) And only runnin 17psi thru 1st and 2nd gear before running 17.8psi thru 2nd and 3rd..
    Now i have a Blitz Access ECU so no more FCD. Cars going on Dyno this week after the Greddy Ex cam gear is installed and dialled in. Will get a new power run at 15.5psi and probably 18psi.
    But it goes to show how far a simple FCD + stock ECU will go. Got me bloody far thats for sure.
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
    Junior Member Domestic Engineer NeoNasty's Avatar
    I have built a Jaycar FCD. Its been sitting around not being finished for about 1.5 years.
    I finished it and after some trouble shooting its running great on the bench. I'll do a bench test and clamp it to 4.3 Volts and see what happens when its in the VN. I never hit boost in the Soarer as its stock. I dont even have a boost guage in it.
    You'll have to wait untill the VN is running.
    HZJ75, RS41, JZZ30
    Apr 2007
    How hard are these Jaycar FCD to build ? & Installation just cut into the map signal line to the ECU i presume ... At Jaycar are they sold under the name FCD ... Sorry to ( some poeple ) for the obvious / lame questions, but i have never seen one..
    These aftermarket electronic mods are still a bit new to me, something i have never dabbled with in the past ...
    Thanks in advance ... Rob ...
  8. #38
    Corona loving Grease Monkey TTMX83's Avatar
    This is the DIY FCD in my Cressida:
    It has been working fine for over six months and its adjustable. I'm sure some time on a dyno would fine tune it more and come up with similar results to using and expensive aftermarket type. For now though, I can run 16psi and have had no trouble.
    And also a question: Do we measure the voltage with the car running or when it is on boost?
    Cheers Brad.
  9. #39
    Apr 2007
    Not sure if i'am reading this above diagram properly, but would that just adjust overall voltage through the range? I was after something that capped the maximum voltage only..
    i dont know how its done but sure there was mention of it in here ..
  10. #40
    The Fonz Grease Monkey rob_o's Avatar
    Quote Originally Posted by TTMX83
    Cheers Brad.
    Awesome work brad... I did this and it cost me a grand total of $2.05 and I have spare diodes.
    I am running 20psi on factory ECU and injectors with no problems!
    1JZ Toyota Cressida Grande
  11. #41
    I built and fitted that FCD to a guy's car too, worked like a treat. Just dial in the pot until it just defeats boost cut.
    244rwkw / 328hp @ 18psi
  12. #42
    penrith nsw
    I just discoved my boost controller has a fcd set up in it so i didnt even need the hks one
  1. RA28 Intank Idea (Carby to EFI fuel tank)
    By DoctorDubb in forum Tech and Conversions
    Last Post: 23-11-2006, 06:26 AM
  2. fuel setup
    Last Post: 12-09-2006, 08:24 AM
  3. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
  4. weak fuel pump? (1jz-gte lost alot of power)
    Last Post: 23-01-2006, 08:14 PM
