Results 16 to 30 of 42
Thread: 1jz fuel cut defender
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    Default Re: 1jz fuel cut defender
    ahh well i got one on the way now, is it worth putting a safc on a 1j?
    Aug 2006
    Sure if you want to extract every bit of power out of it and know that its safe
    You dont have to but it is piece of mind
    A safc should raise the boost cut so you might not need the fcd too
    penrith nsw
    safc trims fuel mix doesnt it?
    Xistant
    Guest
    Quote Originally Posted by pete05
    i suggest you read up on google what a SAFC does
    saves getting neg'd for such a silly question
    Aug 2006
    yeah its a air fuel controller
    so as it trims fuel it can raise the fuel cut
    I have a good write up on the jaycar version that i can email too you if you want
    Or you could just go down to jaycar and buy their kit book with lots of goodies in it
    penrith nsw
    yeah throw me an email on it if thats ok, just thinking i might be able to clean up the fuel econony a little bit
    Aug 2006
    My bad pete i got confused
    safc is a afm controller
    Hit me up with your email via pm and i'll forward the jaycar one on to you to have a read
    penrith nsw
    pm sent on email
    Doofy,
    you are referring to the Jaycar digital duel adjuster arent you?
    I am referring to the NEW kit - which is a $20 fuel cut defender, KC5439
    http://www.jaycar.com.au/productView.asp?ID=KC5439
    Aug 2006
    Yeah Karl thats the one
    Pete already has a fcd on the way
    He is now looking at fuel adjusters
    The new jaycar fcd looks the goods though
    Even though the clamp voltage is not adjustable 3.9 volts will be fine for the 1j
    Im sure you will start to sell heaps of these!
    don't get a safc yet. Get the FCD installed. Clamp at 3.8v. Go to dyno and check AFR's. If too rich clamp it a tiny bit lower like 3.75.
    Think of it this way. Your ecu knows how much vacuum or boost the engine has by getting its signals from the map sensor. The map sensor reads from 0-5v. 5v being the highest amount of boost it can read to. (search this if you want more info)
    So when you install a FCD you are effectively clamping the voltage that the ecu sees and therefore tricking it into thinking you are running less boost. What this will do is decrease the amount of fuel injected and also run more timing. If it ran too much timing, the knock sensors would detect it and retard timing to keep your engine alive.
    So adjust FCD and aim for 12.0:1 AFR's. If you can get that then IMO you do not need a SAFC or Jaycar DFA.
    QUICKEST 1JZ'S IN OZ
    W.A.
    With a GREDDY FCD and stock computer with a few mods i managed to pull 297hp on 13.5psi, the reason for the FCD was due to the odd boost spike here and there and extra cold weather would cause it to hit fuel cut as well. At 13.5 psi the ratios where around 12:1 and at 15.5psi when i later dynoed it, it was 12.8:1
    So 1psi over fuel cut was no real drama although it is getting a bit close to "un safe" ratios you might say.
    penrith nsw
    Thanks for all he replies guys i have my hks fcd on the way so i will have a play with it when it comes in
    HKS FCD on setting 8 (around 4 volts) got me around 330hp atw @ 18psi. You could lean it out slightly more if you are running lower boost (eg 13-14psi), so maybe put it to around 3.7-3.9V. Not sure what setting number this is on the FCD though.
    So basically the HKS FCD acts as a blanket SAFC/fuel computer, no individual adjustability for various rev points. Does the job nicely though
    244rwkw / 328hp @ 18psi
    Toymods Club Member Domestic Engineer Danners's Avatar
    I have a genuine HKS FCD for sale if interested. It is the standard type
    Dan
  1. RA28 Intank Idea (Carby to EFI fuel tank)
    By DoctorDubb in forum Tech and Conversions
    Last Post: 23-11-2006, 07:26 AM
  2. fuel setup
    Last Post: 12-09-2006, 09:24 AM
  3. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 02:05 PM
  4. weak fuel pump? (1jz-gte lost alot of power)
    Last Post: 23-01-2006, 09:14 PM
