You need to say what Turbo you want to use on it before we can tell you how much Boost (Psi) you can run safely ?
With the standard ECU, I doubt you could safely add an extra 20-30Hp without running lean..... So with that in mind, just Bolt it all on but run in NA mode to get it to the Dyno or track to be tuned.
But once you have the Injectors, Fuel pump (Maybe) and Programmable ECU sorted, the only thing limiting power will be the standard Piston ring lands which I'ld say will let go well before you find the limit of the stock Camshaft, which in NA Engines is always more aggresive then the factory Turbo variants, but better for outright power.
