Results 16 to 17 of 17
Thread: 3sgte sounds like lawnmower
    Junior Member Backyard Mechanic sw20r's Avatar
    Default Re: 3sgte sounds like lawnmower
    have you got access to an aircompressor/airgun?
    clean out your dizzy by blowing it out as water might have gotten in. check out your dizzy cap or rotor button as this is symptom usually happens if you've been driving in the rain.
    before that you can get some wd40 or water displacement spray and try that inside all the leads and cap terminals.
    If you find that your car seems like its wanting to stall definately check the lead coming from the coil to the dizzy. Depending on how old your car is or when you last did the dizzy the seals might have let go and slight water might be going in.
    You might not be over heating as you say your getting only half way temp on the gauge? Bubbling in the radiator cap means you have an airpocket as the MR2 hasn't been filled correctly/bled exactly to factory specs as theirs a special method needed.
    There's two drains that need to be opened when dropping the coolant..
    http://www.mr2-tech.com/bgb/mechanic...ing_system.htm
    My advice is try drying up the leads and dizzy first before you remove the head.
    Quote Originally Posted by danny2
    car sorted itself out while it was running as i was pulling leads out.. i'm 99% sure it was water in one of the cylinders as it had not been running for about 3 weeks and there was quite a bit of water and white smoke coming out of the exhaust..
    sorted...
    i think its got bhg or a cracked head..
    different issue, and a lot more frustrating.
    TRIKKE | Video
  1. 3sgte Limits???
    By Douglas Black in forum Tech and Conversions
    Last Post: 30-11-2013, 10:33 PM
  2. To 3sgte or not to 3sgte
    By General_Bupkiss in forum Tech and Conversions
    Last Post: 23-03-2006, 04:23 PM
  3. 3sgte and 4agze standard weights?
    By Taxi>Maxi in forum Tech and Conversions
    Last Post: 20-03-2006, 06:55 AM
  4. 3sgze Vs 3sgte
    By NeoNasty in forum Tech and Conversions
    Last Post: 18-02-2006, 03:03 PM
  5. 3sge - 3sgte CAS - interchangable?
    Last Post: 20-12-2005, 08:15 PM
