Results 16 to 20 of 20
Thread: oil return line angle
    I like Cheese Backyard Mechanic Jackel's Avatar
    W.A.
    Default Re: oil return line angle
    clock turbo what you on about? :S
    Western Aus
    clocking a turbo refers to spinning the sections around, from what ive seen, spinning the compressor side around while leaving the exhaust side where it is, so you can spin the unit and point the compressor outlet where you need it to go.
    someone correct me if this is wrong!
    Elmo.
    W.A.
    ah ! gotcha never thought of that that might be the answer to my problems
    Quote Originally Posted by Jackel
    Yes
    Rotate the centre of the turbo so that the turbo oil feed inlet is pointing up, and the turbo drain down.
    This will more than likely require rotating the rear and the front housings!
    Seeing as you have an external wastegate you may also find that you will want to rotate the front compressor housing in relation to the rear housing / core so that the pipe work is easiest (when you have an internal wastegate the actuator mechanisms can make it a little trickier to rotate the front housing with respect to the rear housing...)
    it's true the say 'a pic is like a 1000 words' .. or there abouts.
  1. turbo oil return line, 5/8 and 90degree bend....
    Last Post: 17-01-2007, 02:27 PM
  2. Catch can return line?
    Last Post: 03-09-2006, 10:54 AM
  3. oil return line on 7mgte
    By JZA20 in forum Tech and Conversions
    Last Post: 21-05-2006, 05:24 PM
  4. ta22 feed and return fuel line sizes
    By shelldrake in forum Tech and Conversions
    Last Post: 08-02-2006, 10:40 PM
