Results 1 to 15 of 25
Thread: Question on Sparkplugs
    Gorilla Industries Conversion King Koffee-Black's Avatar
    Default Question on Sparkplugs
    Hey guys, sounds like my car is running on 5 cylinders. I chck the plugs, and one has a crack in the white part, is this the problem?
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    Default Re: Question on Sparkplugs
    Possibly causing it, best to replace it anyway
    white part is the insulator. if it is cracked a) the spark may be shorting out from the crack to the suroundings, or b) the conductor down the middle is also cracked..
    may as well change them all while oyu are there (unless you have Pt/Ir ones?)
    ok thanks. I tried it in another bank, and it most def seems to be the plug.
    Hi Guys
    This maybe a bit of a thread hijack (sorry) but can anyone tell me what changing the temperature of your plugs actually does?
    Thanx
    it changes how much heat your plugs suck out of the combustion chamber, and how hot the plugs run.
    google it, do some research!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    What do you guys reccomend me run? 1jZGTE with Haltech E6x
    7mgte with haltec
    Quote Originally Posted by Koffee-Black
    either what toyota recommends (prolly the pt or ir plugs) or what NGKspark.com.au recommend...
    unless you want a different heat range for a special reason.
    Roll Ons? Carport Converter Endless's Avatar
    For a lightly modded 1jz BKR-7E's are the go koffee.
    Thanks. Yeah reccomended stuff dont work to well, they miss all the time. Thats the ones Endless! Thanks! I think I had to gap my ones too.
    Guys, is BCPR-7ES ok? I called up a place, and t hats all they have left in stock
    I have heard of people running the bcpr6-e11 if you can get that one? The 7 just means colder than 6, and I think the 11 means gapped to 1.1mm stock (so regap to .8 or .7mm or so) but not sure what the S means? Search NGK website and see what the difference is.
    *I haven't used the bcpr's as I have just changed from bkr6e to bkr7e and that has seen an improvement in idle quality. Haven't given it a hard run yet though. I was going to try the bcpr7e next time.*
    QUICKEST 1JZ'S IN OZ
    Following is a brief list of various codes found in the NGK spark plugs. This is actually a copy of a document that used to be on the Motorcycle Tuning Resources page. Those pages are apparently down so I decided to post the codes here on the TL pages.
    Example NGK codes:
    [B] [P] [6] [E] [S]
    [D] [8] [E] [S] [-] [L]
    Field one: Thread Diameter A 18 mm
    B 14 mm
    C 10 mm
    D 12 mm
    Field two: Construction C Hex size 5/8"
    K Hex size 5/8" with projected tip (ISO)
    M Compact type
    P Projected insulator type
    R Resistor
    SD Surface discharge for rotary engines
    U semi-surface discharge
    Z inductive suppressor
    Field three: Heat Range 2 Hottest
    10 Coldest
    Field four: Thread reach E 19 mm
    F tapered seat
    H 12.7 mm (1.5")
    L 11.2 mm (7/16")
    If this is blank, an 18 mm diameter plug has 12 mm reach; and a 14 mm plug has 9.5 mm (3/8") reach.
    Field five: Firing and construction A,B Special design (no details given)
    C special ground electrode
    G Racing use
    GV Racing V-type
    H Half thread
    K 2 ground electrodes
    L Half heat range
    LM Compact lawn mower type
    M 2 ground electrode for Mazda rotary engine
    N Special ground electrode
    P Platinum tip (premium)
    Q 4 ground electrodes
    R Delta ground electrode for BMW
    S Standard 2.6 mm electrode
    T 3 ground electrodes
    V Fine-wire electrode, gold-palladium
    VX Platinum tip (high performance)
    W Tungsten electrode
    X Booster gap
    Y V-groove center electrode
    Field six(after the dash): Wide gap 8 .032"
    9 .036"
    10 .040"
    11 .044"
    13 .050"
    14 .055"
    15 .060"
    20 .080"
    L Half heat range
    N Special ground electrode (note: appears to be limited to BMWs)
    That's the one
    Last Post: 17-06-2008, 09:53 PM
  2. Conversion Question?
    By Uzi3L in forum Tech and Conversions
    Last Post: 08-03-2006, 03:20 PM
  3. Another noob 18RG question
    By tricky in forum Tech and Conversions
    Last Post: 22-02-2006, 01:37 AM
  4. Power Steering (n00b question)
    By ZZE92 in forum Tech and Conversions
    Last Post: 29-12-2005, 12:52 AM
  5. ae86 / ke70 comparison question
    By BeRad in forum Tech and Conversions
    Last Post: 14-12-2005, 07:59 PM
