Results 16 to 30 of 41
Thread: AW11 Leaking Fuel Problem
    Default Re: AW11 Leaking Fuel Problem
    correct, what they have done is the *correct* way to do it.. you press a restrictor piece in there and use some sika to seal it. i would imagine if you can remove it then you can just use the original aw11 cap.
    wa
    heres what it should look like :
    you can see mines a bit mangled, thats due to me bending it out slightly to make it seal harder (lid against the neck) as ive had the same issue.
    My Corolla ! - 4AGTE
    KP61 - 4AGE
    北海度
    Shees Adsport.. I have NEVER seen one like that.
    Aus NA's are nothing like that!!!
    JBs My SC does it too.
    My theory is compliancers using random filler necks with random caps.
    Find the right cap for your neck and problem is solved....
    Trouble is that is impossible unlsee you know what neck they used.
    Go to a wreckers and try every different cap lol.
    Or you can buy my Aus delivered filler neck (cap included) and get it installed. Fixed.
    $500 and it's yours ha ha ha.
    Look on the bright side... less paint to sand off when you do re-spray!
    Hopefully it will dissolve all that gay two-tone off for you.... lol ha ha
    Worse comes to worse just spraypaint the shit out of it like Adsport... maybe that's why his is sealed
    Junior Member Carport Converter JBs's Avatar
    Hahaha rep for all (except you Drifty, pffftt one tone ) thanks guys, time to give good old Ray a call and see what he can source for me.
    JB
    Taken completely out of context:
    Quote Originally Posted by ROTFL-ACT
    JB's quite funny
    i think your first port of call should be trying to pull out the falcon insert they have put in there.worst case i actually have another spare one here as well.
    Yep will do, is the old school cap a standard Toyota one, or something specific for the AW11 imports?
    JB's quite funny
    id be guessing genirc old toyota
    北海度
    Quote Originally Posted by TooF
    Aww c'mon man... I'm trying to raise $$$ for the IS
    Quote Originally Posted by Drifty Midship
    I still owe you beer for the headlight
    JB's quite funny
    wa
    mines a JDM filler , identical to aus ae86 also.
    paint in there is from when the rear quater was sprayed with the filler lid off
    KP61 - 4AGE
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    That looks like a pretty average insert installation job there.
    Rip it out and use the standard cap. It's the same as one off an AE82 and probably any other 80s Toyota.
    The problem is that a lot of them have fairly perished rubbers - a new one will set you back about 40 bucks from Toyota but will fix the problem - at least it did for me.
    There should be a reasonable amount of pressure building up in the tank during normal operation, it should hiss when you remove the cap.
    I have a Grease Monkey mr2janai's Avatar
    Aichi
    Do you have to replace the fuel filler when brining an AW11 into Australia still?
    I was under the impression you used to have to do it so you cant put super into an unleaded car. But im guessing that now there is no super available in Aus you dont have to do this change anymore.
    Anyone know?
    AW11 SC
    EP91 Glanza
    when i spoke to my engineer about it he said it was still a requirement despite not being able to get leaded fuel. he did however say it was pretty much just a box ticking exercise.
    wa
    yep afaik you do have to do it , mine was a case of
    DPI : did you change the fuel neck?
    me: yep
    DPI : ok *ticks box*
    KP61 - 4AGE
    yeah mine actualyl checked
  1. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 10:12 PM
  2. Replies: 1
