Results 1 to 14 of 14
Thread: Where to buy this bolt?
    Default Where to buy this bolt?
    Hello,
    Just looking for a bolt suitable for seatbelts(High tensile steel I suppose) with a eye as pictured below. I've got a few of them, but they are 1mm to big and don't fit the existing holes I have, I don't fancy drilling into my bodywork or re-tapping the existing thread I have.
    Can anyone suggest a place in Sydney, or on the net that sells these kind of bolts? Or a racing place that can advise with Harness installs.
    It's unlikely, but maybe one open on a Sunday
    Or does anone have one they want to sell me? Needs to have a 10mm diameter thread, prefereably tapered a little, but not essential.
    Default Re: Where to buy this bolt?
    around the corner from castle hill toyota there's a bolt place open on saturdays (altho maybe not by the time you got there). It might be a coventry's .. I'm sure the CHT ppl could direct you to it. *shrugs*
    there's a place in parra, but the name eludes me at the moment...
    Junior Member Backyard Mechanic STR8 2.8's Avatar
    i dont suppose you're in the south, but southern fasteners in kirrawee has them
    I have a Crown
    Toymods Club Member Backyard Mechanic Big T's Avatar
    The parra place is "Lee Brothers" on Dunlop St just off Church st... if anyone has details of this castle hill place though id be keen to hear it.
    Eddie.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
    wa
    i think the seatbelt bolts may be a different thread pitch and size(11mmX1.00mm rings a bell)but not 100 percent sure on the size but they are different so you cant use one of your seat bolts(the wrong grade)
    a seat belt bolt from any old toyota should be the same
    Ecotechilux - Yup, Seatbolt belts are 11mm, which that ring is, but I need one that'll is 10mm with the ring, same grade, if such a thing exists.....
    Forum Sponsor Conversion King
    Dec 2006
    seatbelt bolts are 11x1 and have to be so no twit grabs a standard bolt and chucks it in only to have the head shear off in a crash thus injuring the occupant.
    BBM at Kings Park have plates 50x70 with a nut welded to the back that you can rivet/spotweld into place.
    well (5min later) just found three such objects lying around the shop and if i look hard enough i could probably find another.
    0410507715 linden
    call if you need such objects but im not sure if im going to be here after lunch so ill take them with me.
    girraween or quakers hill
    seeya
    Coventry fastners for the win, Repco etc sell racing harness's maybe give them a go, just maybe they sell spares.
    Beaumonds (or baumons) in Brookvale. They do balustrading
    NL-34-SH Grease Monkey unleashed__'s Avatar
    May 2007
    Linsell Industrial Suppliers Pty. Ltd.
    TOOL SUPPLIERS
    Industrial Fasteners Suppliers, Special Components Machined or Cold Forged
    Factory 1, 73 Governor Macquarie Drive,
    CHIPPING NORTON 2170
    Tel: 9755 1528 Fax: 9755 1557
    www.linsell.com.au
    opinions are like a** holes.. everyone has one but thinks everybody elses stinks
    Is there a Revolution Racegear near you. They should have them.
    I might have a couple to spare if you're not in a particular hurry.
    PM me if interested.
    Thanks guys for your ideas, Roadrunner sorted me out with a solution
    interesting, i got 4 of these bolts with the harness i bought recently, but i would like bolts that have a shank on them like the factory seatbelt bolts, so i could use the eye bolts in place of the seatbelt bolts, so i can leave them in place for the harnesses, and have them fasten teh seatbelt in all the other times if that makes sense. should really look into it.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Ghetto Goodness Automotive Encyclopaedia Ghetto-AW11's Avatar
    coventry dont sell high tensile stainles steel... as i found out not long ago.
    Homebrew, triumph triple, turbo aw11
    By The Witzl in forum FAQ
  2. 5-ME crankshaft pulley bolt
    By GasedT18 in forum Tech and Conversions
    Last Post: 31-12-2006, 01:21 PM
  3. Help! Spare tyre bolt thingy
    By Camryman in forum Tech and Conversions
    Last Post: 06-11-2006, 01:22 PM
  4. Stuck crank pulley bolt
    By Shifty in forum Tech and Conversions
    Last Post: 05-04-2006, 10:37 AM
  5. Will Front RA60 Discs And Calipers Bolt To Ae86 Struts??
    By nos4ag in forum Tech and Conversions
    Last Post: 14-01-2006, 05:12 PM
