Results 1 to 7 of 7
Thread: Help! Spare tyre bolt thingy
    Junior Member Grease Monkey Camryman's Avatar
    Default Help! Spare tyre bolt thingy
    I finally got around to getting a 15 inch spare tyre for my SV21 Camry and discovered that I can't bolt it down in the boot with the original bolt, which was designed for a 14 inch stock wheel, 5.5 width. It's about 1 cm too short now.
    I need the 15 inch spare to fit over the bigger Celica brakes at the front.
    Is there an easy solution to this? Are there generic bolt available at the local Supercheap autos? If all else fails I'm hoping a Celica and VZV21 Camry spare tyre bolt will do the trick. I went down to Toyota Spares but the bolts they had were either too short or too long.
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    Default Re: Help! Spare tyre bolt thingy
    If you can find one a little too long just cut it a bit shorter.
    regards
    jon
    Take the original with you to a good nut and bolt shop, see if you can get some threaded rod which is the same thread, also buy a fitting (maybe a wingnut and another nut or two to lock it off) to put on the end of it to screw it down with
    The whole exercise should cost a few bucks and will do the job perfectly
    I am the sun
    as dale said, heres an easier solution which is the same, bunnings sell booker rod which some call all thread, which is just rod thats all threaded funnily enough., they sell it in lengths of about a metre and in all different thread sizes, cut it to size and as dale said get a wingnut and bobs your aunty
    Thanks for the info.
    Sounds like I will have to make the whole thing up from scratch as the rod doesn't come out of the bracket.
    Going to pick a part and sourcing one that suits isn't an option?
    Quote Originally Posted by gianttomato
    You mean going to an auto wreakers?
    I suppose I could do that as well.
    By The Witzl in forum FAQ
