Results 1 to 15 of 18
Thread: RA65 intake air temperature sensor
    Default RA65 intake air temperature sensor
    hey i'm just wondering if anyone knows where the intake air temperature sensor is on the 22RE?
    Montrose
    Default Re: RA65 intake air temperature sensor
    Next to the airflow flap
    where bouts is that? what does the plug look like? sorry i dont know much bout engines yet...
    Montrose
    The funny shaped contraption attached to the airbox. The plug that goes to it does airflow, fuel pump switch and temp. Are you thinking of trying to stick a resistor in it or similiar? You can make much bigger changes by removing the airlfow meter lid, and fiddling around with the knob inside there - don't expect to start making massive power gains though!
    nah not a resistor i got a performance chip that i need to wire up to the sensor.
    Does it perform?
    Quote Originally Posted by Celica RA65
    Performance chip = 30c resistor you just paid $30 for.
    its meant to put about 20-30 extra hp depending on the car.
    And you got it off eBay right?
    This is solid gold right here.
    Montrose
    Poor bastard.
    You were fed lies. Sorry.
    The purpose of the device you have is to fool the engine computer into thinking the engine is cold all the time, so it will increase fuel flow to the engine and make the air/fuel ratio (AFR) richer. The theory is that richer AFR's will make your car perform better, which sounds plausible to someone who doesn't know about engines - but the reality is, richer AFR's will actually make the engine perform worse and dramatically increase fuel consumption to boot.
    The only sensible option is to put your "performance chip" where it belongs - in the bin. You have absolutely nothing to gain by putting it anywhere near your engine. Sorry if you got ripped off, but if it makes you feel any better you're far from alone - there's a whole range of these bogus "performance products" out there and people keep snapping them up.
    *gives celica RA65 a big hug*
    sorry to hear you got done
    fiddle with the AFM switch, rip off the pollution gear, new air filter (by this I mean the pape element, not a ricer pod filter - altho the induction noise of a 22r with a pod is GREAT), put new sparks and oil in... these are the best low level mods for the 22R
    Norbie,
    To the best of my knowledge, these are for the air intake temp sensor, which fools the ecu into thinking the air is colder, thus adding some more timing, and producing more power.
    However, this can (and will) make the engine ping on hot days.
    Montrose
    22R needs no help pinging...
  1. 4agze fault codes & diagnosis + Pulley
    By Poggy in forum Tech and Conversions
    Last Post: 01-05-2007, 10:11 AM
  2. Water Temperature sensor Ohm value?
    Last Post: 14-05-2006, 10:00 AM
