IIRC = if i recall correctly
i'd actually recommend the e153 out of the v6 camry's of later generations. they'll be a tad easier to source, and easier to bolt right in. else worse comes to worse the mr2 is always feasible.
try talking to some of the importers here on toymods eg, cvap, importbitz, and ask what they'd charge to bring it over.the only reason being you might be better off with the rear cut.
if this is not possible get pictures of the underside as they had the fuel tank to the side and also you'll definitely need to get the locations of all the rear diff cradle mounting points.
if its anything like the celica's your in for a long conversion, but it'll be different
other things are the manual to auto conversion. have a look at the conversions subforum and find Jetspeedcamry's v6manual swap thread. he details the procedure required to make the vzv chassis become manual friendly. things such as drilling for the clutch slave, different locations for the auto vs manual shifter cables etc.
the st184 box should still be manual speedo cable so you should be fine, else i'm pretty sure you can work something out to fit a manual sensor into the box. check jetspeedcamry's thread for how he did his.
some of the celica boy's with 3sgte conversion seem to be doing fine with the s53/s54 box's so dont worry about that aspect too much. hmm anything else just ask![]()
