Results 16 to 22 of 22
Thread: Stalling When Stopping.
    Default Re: Stalling When Stopping.
    and how do i know if its getting flooded whilst driving ?
    If started in my driveway , idles at about 1.2k as we turned the idle screw up just a tad (stock was ~800) without failing, but once drivin it will stall
    eg.
    Im going 60kph. up a street , lights turn orange, start breaking ... all is well ... once i get close to a dead stop .. STALL
    where can i find my jets to clean ?
    on the carby you will have a fuel level inspection window....only a little clear hole that you can see the fuel level in the bowl,.
    the level should be in the middle of the inspection hole,
    if its at the top, you are gettng too much fuel, and floodying the motor.....as you say you have to mash the pedal a few times to keep it going, to suck that fuel in....
    if the level was just on the bootm of the bowl,...you would have trouble driving it hard, and would likely have to be drivem with light pedal applications,
    sounds like it could be flooding.....
    but check all your vaccuum lines, (you just did the head didnt you) they are real bitch when it comes to poor idle....
    blake
    Tasmania
    Also i forgot to ad,
    When in Park it will idle fine, and if say im going 60kph up the street and need to come to a stop, if i put it in netural and start to break coming up to the lights/stop sign it wont stall
    :s
    Adjust the idle on the carb while the car is in drive with the handbrake on and I will guarantee that it should fix your stalling problem.
    Cheers Brett.
    Montrose
    Does it maybe have one of those little things that turns off the idle solonoid when the vacuum is above a certain amount, which is supposed to act as an overrun fuel cut, and it is a bit crook? Try connecting the idle valve straight to power and see if it does it.
    Quote Originally Posted by crowncustom
    Cheers Brett.
    we tried that, didn't work..
    i rang up and confirmed, i believe we do have the same motor..
    problem was, at idle, and especially after a drive, the cams didn't generate enough vacuum to power the fuel pump.. something about heat and expansion, and the petrol not rising to the carb hence a stall. Was also told it might have to do with the length of the hose and the pump not generating enough pressure at idle.. Re-starting it back again with little throttle brings the engine right back up.. it only occurs after 10 minute or so drive...
    West Australia
    would putting an inline pump (small) and remove the mechanical fix this issue ?
    or is that stupid ?
    or is that stupid ?
    i vote for the pump.. if it doesn't work i'll buy you some beer
    or is that stupid ?
    most likely a 20yr old mechanical pump.....so anything other than that is an upgrade....
    plus electric carby pumps are dirt cheap too.....like $50 from supercrap
  1. Help with Non-Toyota (excel) stalling
    By Mexican 5 in forum Tech and Conversions
    Last Post: 18-04-2007, 11:17 AM
  2. Over revving on start up and stalling for no reason on a 6MGE
    By Johnzoku in forum Tech and Conversions
    Last Post: 18-02-2007, 07:43 PM
  3. 4AGZE AE-101 Stalling With FMIC
    By dave_101 in forum Tech and Conversions
    Last Post: 01-02-2007, 10:13 PM
  4. Fixing your stalling 4A-C Engine
    Last Post: 18-09-2006, 08:23 PM
  5. AE82 Twin cam speedo stopping at 30
    By CussCuss in forum Tech and Conversions
    Last Post: 23-05-2006, 09:27 PM
