Is the air con on when it happens?
Hi all ,
Just need some help with the only issue left with my Cresta.
The engine is all sweet, idles fine etc etc
drives fine, no smoke
nice and smooth.
Only issue is when i slow down and come up to lights once the car completely stops it will stall , which i can put it in park or neutral again and start it , and drive again ...
Sometimes just before it stalls you can smash the accel a few times and it will keep going ..
The engine is a 1S-U 4Cyl, 1.9 Carby
which is almost identical to a 2S found in ST141 etc.
Could it be fuel pump issue or a break booster issue ?
all help much appriciated.
<3
John.
I am the sun
Sounds like your idler Jets could be blocked, Dales point about the Aircon is valid to. idler jets are pretty easy to pull out and spray with carby cleaner worth a try if you dont figure it out.
Did you do the idling while the car was in drive with the handbrake on?or in park?
Cheers Brett.
seems that his is a common problem in 4age's. I've had this issue and what i was suggested by (lunar_c i think it was) was to clean out the TB, ISCV and adjust timing if needed.
So far it has worked
Although in my case the car did have some idling issues where it'd drop to 600 at one set of traffic lights and then idle normally ~900rpm at the next set, so your problem might be something else.
I have been pruned by old man river!!!!!
hm
it's the fuel pump...
it's very common problem in my country with the cressidas that have the same 4 cylinder carburettor motor.. ... it only happens when the car is stopped... a bit like the 4A-Cs and that diaphragm thing where it pushes in more fuel... except it's more predictable..
ur fuel pump is vaccum driven is it not?
well i dont have a ISCV , as the 1S is a old school carby it doesn't have that either...
gonna try cleaning the TB with some carby cleaner ... mattae86 knows some trick we might try to .. he wont tell me what it is ...
More ideas plz ..
if there is a trick, i'd like to know as well.. (if it doesn't involve an electric fuel pump)Originally Posted by Vios-GT_07
nah not vaccume drivin , mechanical (off cam)
the idler isn't flooding your carby is it? my mate's mini had issues with part of the carby getting too full of petrol and causing idle issues after driving (nb: I have no idea about carbies or proper terminology, so I can offer nothing more specific)![]()
yeap that's what i meant.. mechanical fuel pump driven off the cam..Originally Posted by coFF33
oh well... (grr... hate it when i do that)..
let us know how u go![]()
i think "float level" may be the word your afterOriginally Posted by Draven
that one! +rep
and how do i know if its getting flooded whilst driving ?
If started in my driveway , idles at about 1.2k as we turned the idle screw up just a tad (stock was ~800) without failing, but once drivin it will stall
eg.
Im going 60kph. up a street , lights turn orange, start breaking ... all is well ... once i get close to a dead stop .. STALL
where can i find my jets to clean ?
Also i forgot to ad,
When in Park it will idle fine, and if say im going 60kph up the street and need to come to a stop, if i put it in netural and start to break coming up to the lights/stop sign it wont stall
:s
