Results 1 to 14 of 14
Thread: SC12 gasket part number
    Junior Member Grease Monkey minimechanic's Avatar
    Default SC12 gasket part number
    i need the inlet side gasket
    so rang up toyota and they said they would need a VIN number from a car that the sc12 came out of to track down the gasket (i have the supercharger but no levin/mr2).... so if anyone's got an SC12 gasket part number... or should i make my own gasket???????
    suggestions.................
    New Zealand
    Default Re: SC12 gasket part number
    is it a gasket? or sealant?
    if you get stuck email me and ill sort at work
    home pc with epc is dead
    please, no more PMs!
    Insert whitty comment her Automotive Encyclopaedia blacktop's Avatar
    Aug 2006
    which one? far right or lower laft
    http://i174.photobucket.com/albums/w...pirit/sc12.jpg
    Quote Originally Posted by minimechanic
    http://www.toymods.net/forums/showthread.php?t=23369
    Quote Originally Posted by blacktopspirit
    Yeh the far right is the intake pipe-to-throttle body gasket, nothing to do with the sc.
    perth
    model e-ae92-bcmxr
    frame No ae92-5032831
    theres a gze vin number
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    Just use some good gasket goo or make one out of cardboard.
    You don't need to give Toyota a vin to get the part number - the dude you spoke to was being lazy!
    Just tell him what model and year it came from (ie '87 AW11).
    Terry
    [QUOTE=Starfire]Just use some good gasket goo or make one out of cardboard.
    Terry[/QUOTE
    True true. Most import VIN's wont come up in an aussie EPC anyway... So they have to search by make and model...
    Your part number is the next weet-bix box that becomes available ay home, combined with a bit of sealant. Has worked fine for me with just sealant no gasket at all.
    meh...
    Nurses rock! Grease Monkey lunar_c's Avatar
    Feb 2007
    I just rebuilt a GZE and for this gasket I traced the outline of the old gasket onto some ACL oil jointing paper, which is about 80c a sheet, then coated it in a thin smear of silastic. The engine runs 12psi and has no problems - this is essentially what the original is made of.
    i made my s/c inlet/outlet pipe gaskets with 0.8mm gasket paper and a ball pien hammer. little Hylomar on assembly and all is sweet.
    New Zealand
    yep. they were being lazy.
    no import numbers will work on the aussie system (which SUCKS by the way....)
    for interests sake, the part number is 17849-16010
    sweeeeeeeet
    thanks for the help i'll make one myself!!
    original toyo will be a joke at how much they wanna charge me as well.....
    perth
    ive always used import numbers due becuase we never got those cars here ?
    New Zealand
    retail here is $5sumthing.
    but id bet its not in stock!!
  1. JZA70 and MA70 Specifications
    By twentyEight in forum Tech and Conversions
    Last Post: 18-12-2016, 10:18 AM
  2. Timing belt part number & Toyota can not find it. Help please.
    By Nick T in forum Tech and Conversions
    Last Post: 17-08-2006, 07:51 PM
  3. vacum sensor part number
    By bassy in forum Tech and Conversions
    Last Post: 09-07-2006, 09:02 AM
